speedometer problems please help
Old Sep 9, 2005 | 09:27 AM
92LsTegra's Avatar
Default speedometer problems please help
just a few min ago i was on my way home from class and my speedometer started acting up. as i went from a stop it would jump rapidly up and down at random MPH's and then start acting normal after 50mph, 5 min later down the road it starts doing it there too, and then 2 min later it just drops to 0 no matter how fast im going, every once in a while ill be at about 50 and it will jump around again and go back to 0. i threw a CEL light but shut the car off and saterded it and drove it and the CEL was gone but still had the problem. any one help?
92 integra rs original motor and tranny
Old Sep 9, 2005 | 09:29 AM
txracer's Avatar
Default Re: speedometer problems please help (92LsTegra)
do the speedo work by cable, if so it could just be loose in the back of the cluster or where the calbe hooks up i think its the tranny..
Old Sep 9, 2005 | 09:45 AM
SYTFU Tommy.'s Avatar
Default Re: speedometer problems please help (txracer)
check ur speedo cable since u dont have a VSS, the speedo cable should came loose which also threw the CEL
Old Sep 9, 2005 | 09:46 AM
92LsTegra's Avatar
i am not positive if its cable or not, i dont think it is, its a 92 teg rs, i cant really get under it and check, ive only looked from the top. and what do you mean you think its the tranny? where the cable goes in?
Old Sep 9, 2005 | 09:48 AM
92LsTegra's Avatar
Default Re: speedometer problems please help (tngay)
would you have any idea where my speedo cable would go in to the tranny? i dont have much time b4 work im want to try and fix this within the next hour. again 92 rs teg.
Old Sep 9, 2005 | 09:51 AM
Sic's Avatar
Sic
did u check the connection where it goes into the cluster?
Old Sep 9, 2005 | 09:55 AM
92LsTegra's Avatar
Default Re: (Sic)
not yet but i cant do that at the moment i have to be off to work in 30 min, ill have to do that another time. but is there anything else i can check out that wont take oo much time?
also can i damage the cable or anything by driving it this way?
Old Sep 9, 2005 | 10:19 AM
vinai's Avatar
Default Re: (92LsTegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92LsTegra &raquo;</TD></TR><TR><TD CLASS="quote">not yet but i cant do that at the moment i have to be off to work in 30 min, ill have to do that another time. but is there anything else i can check out that wont take oo much time?
also can i damage the cable or anything by driving it this way?</TD></TR></TABLE>
It does not take that long and is most likely going to be the cause of your problems. If you need instruction just e-mail me I have the instructions and locations for the cable.
crxblues
Dec 6, 2006 10:44 AM
EF9 JAMS!!!
Mar 26, 2006 01:27 PM
BigDawwg6969
Feb 25, 2006 05:35 PM
brian349
Oct 26, 2005 04:59 PM
rasta420
Jul 7, 2002 07:50 PM
