speedometer not working
Old Dec 13, 2009 | 11:40 PM
xiapher's Avatar
Default speedometer not working
soo idk what happened i replaced my clutch and after now my speedometer and odometer dont work and i have a check engine light after the car warms up????
Old Dec 13, 2009 | 11:56 PM
DOUBTS.72's Avatar
Default Re: speedometer not working
..did you maybe just happen to pull the Speedo cable back wile replacing your clutch(curious), and maybe it just unplug from your cluster ?,,,and maybe that's why your speedometer and odometer don't work?...my suggestion is that you check the Speedo cable is plugged in all the way in the back of the cluster and on the other end which is the tranny. GL!....oh for got to add ...Your Check engine light wont come on when your car is warmed up, you need to run it for a a few minutes and eventually it should come on.
Last edited by DOUBTS.72; Dec 14, 2009 at 12:00 AM. Reason: add..Check engine light.
Old Dec 13, 2009 | 11:59 PM
xiapher's Avatar
yea i checked the plug that is located at the top and its connected and idk how in the world the cluster could have been affected cause nothing was touched in there and what black wire r u talking about
Old Dec 14, 2009 | 12:01 AM
xiapher's Avatar
oopse never mind the black wire thing read that wrong
Old Dec 14, 2009 | 12:09 AM
DOUBTS.72's Avatar
huh?...kinda get the first part...its called speedo cable/wire(believe it has a sensor "speed sensor") it's on top of the tranny', and runs through the fire wall into your cluster.
Old Dec 14, 2009 | 12:14 AM
xiapher's Avatar
hmm ok ill well my vtech isnt working either so im guessing thats all intertwined ok well ill have to check everything tomorrow ive unplugged the connection on top of the tranny like 4 times even checked the fuse for it but no luck so far so cluster is me next option
Old Dec 14, 2009 | 12:18 AM
DOUBTS.72's Avatar
ya try that goodluck *update when fixed.
Old Dec 14, 2009 | 11:25 PM
xiapher's Avatar
ok sooo i checked it all and guess what problem is still not fixed .... should i try to depin the connector at top of tranny and connect to see if that fixes the problem cause the connector seems to not wanna fit together without force????
or spend 130 bucks on a new speed sensor???
anyone else have any idea
GabesEF909
Sep 24, 2012 09:16 AM
tavo.760
May 5, 2012 02:19 PM
crxtreme27
Jan 19, 2005 05:48 PM
d16X
Dec 21, 2004 10:48 AM
team2n1hatch
Apr 24, 2003 05:07 PM
