spedometer
Old Dec 28, 2007 | 10:26 AM
93dagsr's Avatar
Default bezel
ok i've tried to pull out my spedometer on my 93 integra gs (da) and the garnish that goes around it won't come off at all! on the left where the fog light, dimmer, and moonroof switch are come off perfect, but the side where the defrost is doesn't want to snap off at all! i've pulled really hard and ended up creasing it a little! is there something that i can do or better yet does anyone have a diagram or pic to show me how/what to do?? thanks! o and im pulling it out because the spedometer isn't working.
i think its number 9 in this diagram
http://www.oemacuraparts.com/p...gid=0
Old Dec 28, 2007 | 12:14 PM
93dagsr's Avatar
anyone?
Old Dec 28, 2007 | 12:22 PM
imsickofrice's Avatar
Default Re: (93dagsr)
check and double check and maybe even triple check for more screws. theres always one hidden somewhere thats a PITA to get to~
Old Dec 29, 2007 | 03:11 PM
God-Driven's Avatar
If I remember correctly ther is 5 bolts holding the cover in place 2 are on the bottom to get to this you have to remove the lower cover, ther other 2 are on the top easy to find and the last one is on the far right corner you have to remove the little cover to get to it.
Old Dec 29, 2007 | 04:41 PM
clean3two3's Avatar
Default Re: bezel (93dagsr)
before you started pulling on it did you check the sensor on the transmission because sometimes the sensor that goes to the tranny gets messed up and you can just replace without touching the needle in the dash.does you mileage counter still work or is it the needle that does not work anymore?
anyone correct me if im wrong
Old Dec 31, 2007 | 06:16 AM
93dagsr's Avatar
Default Re: bezel (clean3two3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by imsickofrice &raquo;</TD></TR><TR><TD CLASS="quote">check and double check and maybe even triple check for more screws. theres always one hidden somewhere thats a PITA to get to~ </TD></TR></TABLE>
i did and i got 4 screws....whats pita??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by God-Driven &raquo;</TD></TR><TR><TD CLASS="quote">If I remember correctly ther is 5 bolts holding the cover in place 2 are on the bottom to get to this you have to remove the lower cover, ther other 2 are on the top easy to find and the last one is on the far right corner you have to remove the little cover to get to it.</TD></TR></TABLE>
i got 4?? two of the top ones, and two under the steering wheel.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean3two3 &raquo;</TD></TR><TR><TD CLASS="quote">before you started pulling on it did you check the sensor on the transmission because sometimes the sensor that goes to the tranny gets messed up and you can just replace without touching the needle in the dash.does you mileage counter still work or is it the needle that does not work anymore?
anyone correct me if im wrong</TD></TR></TABLE>
yea i made sure i checked that before i started pulling anything. nothing works speed or odometer.
any other advice?? this thing is driving me crazy and i don't wanna crease the bezel any more than i have! thanks in advance!
Old Dec 31, 2007 | 09:47 AM
clean3two3's Avatar
well i dont know i have the same problem but my rpm needle still works so im cool with that but kinda miss how fast i go.
Old Dec 31, 2007 | 09:56 AM
93dagsr's Avatar
Default Re: (clean3two3)
haha yea i know my rpms, just not how fast im going
Old Dec 31, 2007 | 12:33 PM
DA_9's Avatar
Ill help out, if ur in 5th gear on an LS TRANNY and ur at about 3,000 RPMs then my friend, ur at 60 mph, oh yea.
Old Jan 2, 2008 | 06:14 AM
93dagsr's Avatar
Default Re: (DA_9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA_9 &raquo;</TD></TR><TR><TD CLASS="quote">Ill help out, if ur in 5th gear on an LS TRANNY and ur at about 3,000 RPMs then my friend, ur at 60 mph, oh yea.</TD></TR></TABLE>
hahaha nice! but i got a gsr motor and gsr cable tranny
Old Jan 3, 2008 | 10:56 AM
93dagsr's Avatar
any advice??
Old Jan 3, 2008 | 01:43 PM
Fern413's Avatar
jus make sure everything is clear....nothing in the way...I was replacing my speedo cable the other day and ran into the same problem....only thing was that theres a hook that holds the cable in place....jus pry the cable out
Old Jan 4, 2008 | 08:23 AM
93dagsr's Avatar
Default Re: (Fern413)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fern413 &raquo;</TD></TR><TR><TD CLASS="quote">jus make sure everything is clear....nothing in the way...I was replacing my speedo cable the other day and ran into the same problem....only thing was that theres a hook that holds the cable in place....jus pry the cable out</TD></TR></TABLE>
i got the cable part down its just that stupid bezel i cant get out. it gets stuck where the climate control is. the **** part hot/cold more air, less air. and i can't figure out if theres a clip, screw, or something else there. i figured out that on the right side there was a screw hidden but thats it...... so still need help..
Old Jan 4, 2008 | 09:30 AM
Fern413's Avatar
jus remove both ***** from the climate control....then pry out the the black climate control cover....once that is removed then theres two or three screws...
Old Jan 5, 2008 | 04:52 PM
clean3two3's Avatar
http://www.g2ic.com/tegtips/interior/21.html
go their and see how to take the cluster out
Old Jan 5, 2008 | 05:13 PM
S1NFUL RL1 619's Avatar
check the vss again... because if your spedo and odo both aren't working... then i would check the vss again... just because the wires check out.. doesn't mean that it still can't be messed up.
Old Jan 5, 2008 | 06:14 PM
Fern413's Avatar
Default Re: (S1NFUL RL1 619)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S1NFUL RL1 619 &raquo;</TD></TR><TR><TD CLASS="quote">check the vss again... because if your spedo and odo both aren't working... then i would check the vss again... just because the wires check out.. doesn't mean that it still can't be messed up.</TD></TR></TABLE>
wires????...this is a cable speedo
Old Jan 5, 2008 | 06:26 PM
PACT man's Avatar
I don't remember which side it was on but either the left or the right circled area with the arrows to them are little covers that you can pop out and one has a screw behind it and thats what is getting you stuck.
Old Jan 5, 2008 | 06:59 PM
clean3two3's Avatar
what he said ^ is what got me stuck and i gave up.so did the diagram help
Modified by clean3two3 at 8:21 PM 1/5/2008
Old Jan 7, 2008 | 06:32 AM
93dagsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PACT man &raquo;</TD></TR><TR><TD CLASS="quote">
I don't remember which side it was on but either the left or the right circled area with the arrows to them are little covers that you can pop out and one has a screw behind it and thats what is getting you stuck.</TD></TR></TABLE>
found it!!! thanks! <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fern413 &raquo;</TD></TR><TR><TD CLASS="quote">jus remove both ***** from the climate control....then pry out the the black climate control cover....once that is removed then theres two or three screws...</TD></TR></TABLE>
i took off the ***** but i couldn't pry off the climate control face plate.... ima try and see what i can do tonight! thanks for all the help you guys!!!
eagarcia88
Honda Civic (2001 - 2005)
Apr 18, 2011 06:05 PM
KILLAB17VTEC
Aug 13, 2010 04:21 AM
taimysho0
17
Jan 17, 2009 12:05 PM
MyEfSi2Slow
Aug 3, 2008 07:17 PM
krnboixshawn
Feb 4, 2003 10:21 AM
