Spark Plugs
Old Dec 12, 2001 | 08:27 PM
civicdragon's Avatar
Default Spark Plugs
What kind of spark plugs are you guys running in your cars? Stock plugs or are you running aftermarket? If aftermarket, what are you using? I'm planning to get some better plugs so I can have a better fuel burn. I was looking at NGK Platinum V-Power. What about the irridum ones are they any good?
Old Dec 12, 2001 | 08:33 PM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Default Re: Spark Plugs (civicdragon)
I believe NGK BKR6E-11's. They are copper. I change them about every 15k miles and they are about $2/ea.
Old Dec 12, 2001 | 08:49 PM
speedymon's Avatar
Default Re: Spark Plugs (Gee3)
I use the NGK platinums as recommended by the factory (GSR). Is it safe to run coppers?
Old Dec 12, 2001 | 08:50 PM
Vtec integra's Avatar
i run denso iridiums
they're alrite, but 15 bucks each
if you have close to stock parts ngk's are fine
Old Dec 12, 2001 | 08:53 PM
Default Re: Spark Plugs (Vtec integra)
Well i want some that will give me a better spark and fuel burn... so I'm not looking for stock parts, and money is no issue when it comes to my cars performance... I'm also looking to get plugs one step colder because i might be adding a zex kit soon...
Old Dec 12, 2001 | 08:57 PM
Gee3's Avatar
Default Re: Spark Plugs (speedymon)
Yes, it's fine to run coppers. There is no clearance problems with the NGK BKR6E-11 plugs. The only diff is that copper is a better conductor of electricity but they wear out faster, that's why I tend to change them sooner. The Platinums are still good but I guess I'm cheap! hehe! I've been running coppers for about 20k of the 37k miles I have on the GSR.
Old Dec 12, 2001 | 08:58 PM
Gee3's Avatar
If you use the Zex kit and money is no object get the ZEX plugs as well.
Old Dec 12, 2001 | 09:01 PM
denso's are fine too if money's no issue
oh your feul burning problem might be your oxygen sensor
Old Dec 12, 2001 | 09:11 PM
I'm not haveing a problem just looking for a little extra performance...
How much are the zex plugs?
Smokey5176
May 8, 2007 05:01 PM
gsrguy
Jan 23, 2004 07:04 AM
skierGT
Jun 17, 2003 05:06 AM
GRAVEDIGGER
Jun 18, 2002 01:48 PM
Babalouie
Jun 24, 2001 07:33 PM
