Spark Plug Question
Old Mar 6, 2002 | 07:27 AM
Kolijian's Avatar
Default Spark Plug Question
I've got a 95 Gsr with TypeR cams I/E. Toda cams gears, Short Ram Intake, test pipe with 2 1/4" s/s HKS exhaust. I was running NGK platinum 6's and changed to 7's. Not sure which one is better to go with. Suggestions are welcomed. I've got a match up tonight at the track and need good responses quickly. Thnaks
Old Mar 6, 2002 | 09:22 AM
berkel's Avatar
Default Re: Spark Plug Question (Kolijian)
I don't think you need the 7 range plug for your setup, since you still have stock compression. The colder plug may cause fouling? Either way, it probably won't make too much diff.
Thoughts?
FB
turboedsupe
Feb 17, 2009 06:25 AM
81CB900C
Aug 16, 2007 09:07 AM
HypnotikEFX
May 2, 2005 09:11 PM
AsianMullet
Nov 8, 2003 10:46 PM
shadowdawn
Mar 17, 2003 06:49 PM
