spark plug, leaking is this a problem? - see pic
oil shouldnt make it past the rings of the piston in that amount...i dont think you have a leak...you sure you didnt spill something??? because itd be real unsual to see that amount of oil make it up there
If that is oil, you could have a blown headgasket...Remove that sparkplug wire and try to remove as much of that oil with some rags...Check the rest of your plugs, because it might not be the only one that is flooded...New headgasket and head resurfacing is needed GL!
Remove the sparkplug wires and take picture and post it so that I can take a better look at the problem...
