SOMEONE'S GOTTA BE ABLE TO HELP ME...PLEASE!!!! THIS IS A CONFUSING PROBLEM..
Old Jul 7, 2007 | 04:38 PM
superjet701's Avatar
Default SOMEONE'S GOTTA BE ABLE TO HELP ME...PLEASE!!!! THIS IS A CONFUSING PROBLEM..
AIIGHT...I HAVE NO FUEL I CHECK THE LINES AND TURNED IT OVER WITH A FUEL LINE DISCONNECTED....THEN I CHECKED FOR SPARK AND THERES NOTHING...MY MAIN RELAY IS MAKING A LIGHT CLICKING NOISE AND SO IS THE THROTTLE BODY AND FEUL PUMP....I'M STUMPED AND BEEN PLAYING AROUD WITH IT FOR DAYS NOW...SWAPPED THE GSR INTO THE EG HATCH AND IT RAN GREAT...WENT TO SCHOOL AND THE CAR SAT FOR A YEAR CAME BACK AN NOW I HAVE A KILLER PROBLEM...WHAT TO DO?
Old Jul 7, 2007 | 07:42 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: SOMEONE'S GOTTA BE ABLE TO HELP ME...PLEASE!!!! THIS IS A CONFUSING PROBLEM.. (superjet701)
IS THERE FUEL IN THE TANK?
PULL THE REAR SEAT AND CHECK FOR POWER AT THE FUEL PUMP. IF THERE IS POWER, AND NO FUEL FLOW, REPLACE THE PUMP.
YOUR THROTTLE BODY IS CLICKING?
BTW: Turn off the caps lock.
Old Jul 8, 2007 | 12:38 PM
Jdmdc4ls's Avatar
well is there any fuel in the tank? thats one thing u needa figure out. check the fuses, if not than fuel pump? spark plugs? wires? do one by one. process of elimination. it can be one simple thing or it can be a number of things.
Old Jul 8, 2007 | 06:25 PM
CubanLynx84's Avatar
Default Re: (Jdmdc4ls)
if the car has been sitting for a year with the same fuel in it then the fuel is bad first off. After a while gas turns into turpintine so you need to drain the fuel and put fresh fuel in. if the main relay is clicking then that might be bad too. Also dry rot of the seals on the motor can be a factor as well.
Old Jul 8, 2007 | 06:54 PM
lazieb29's Avatar
have you checked your battery? they drain if you leave it sitting.
str8kustomz
Feb 2, 2015 03:24 AM
project92ex
Oct 25, 2008 11:00 PM
Jap_Spec_Imports
14
Sep 26, 2006 02:11 PM
crazygerman
Mar 4, 2006 11:57 AM
brian3676
Dec 31, 2005 09:58 AM
