solve this one!
I have a 94 ls obd-1. I bought a factory alarm system from a 94 gsr obd-1. SO i thought the alarm would fit. well it does! the only problem is my car wont start with the alarm installed! I went throught the A-K wiring harness (p/n 08E55-ST7-201)and tried to start my car with each pull of a plug. and bammm! i found it, its harness "G". Just so everyone reading knows the harness has a male and female harness for each plug one to plug stock harness into alarm harness then alarm harness to the stock harness input. SO I just kept the stock harness in the "G" spot. my car runs with the entire harness inplace except "G", but now the alarm doesn't work. It is a 7 pin harness with 3-8 gauge wire and 4-20 gauge wires (im pretty sure on wire size). Anyone know whats going on!!
the alarm probably thinks someone is trying to steal the car so when you plug in the wire the alarm shuts off the car. does everything else work like lights stero? i had this problem when someone put the wrong sized fuse in. i tryed staring my teg and ... nothing noit even a sound so it was my alarm thinking someone was trying to steal my car.
the stock acuras have a fuel cut off well my 91 teg with stock alarm has that... to answer your question i would check the fuse to see uf thats the problem. then make sure everything is connect right. not much more you can do.
what fuse on the harness or the actual fusr box, my car runs without "G" hooked up and alarm doesnt work, when alarm is hooked up (all harness's connected) my car doesn't turn over! so I wouldnt think it would be the fuse in the harness only becasue the car alarm works! im so confused to what is going on, it doesn't make sense!
kchungb17a
Audio / Security / Video
Jan 12, 2006 08:58 AM
