solid urathane mounts....
Old Sep 19, 2002 | 12:09 AM
infamousALLMTR's Avatar
Default solid urathane mounts....
has anyone attempted to make these on there own?
this is what I found out on the subject....
http://www.ludespeed.com/products/pr...olidmount.html
Is there anywhere else you can buy the stuff to do it?
Old Sep 19, 2002 | 08:36 AM
InfamousRS's Avatar
Default Re: solid urathane mounts.... (infamousRRH)
I was at Home Depot last night and saw that they had Poly Urathane.....would that work to fill my mounts with?
Old Sep 19, 2002 | 09:24 AM
Default Re: solid urathane mounts.... (InfamousRS)
any help?
Old Sep 19, 2002 | 12:22 PM
ragejed's Avatar
dunno,people say its ghetto..but if it works..to each his own.
Old Sep 19, 2002 | 04:13 PM
vteg's Avatar
New User
I have seen this same thing done elsewhere also. It works from what I have seen, but I could only reason going through the hassle if you own a car that companies do not make poly inserts for. Some people don't like the added harshness. The inserts are 30, but you can remove them if you don't like them. This does not seem to be reverseable.
Old Sep 19, 2002 | 04:27 PM
Default Re: solid urathane mounts.... (vteg)
but those only go into three mounts excluding tranny and driver side
Old Sep 19, 2002 | 05:31 PM
Weston's Avatar
Which section do they keep that in? It could be useful for other projects...
Old Sep 19, 2002 | 08:24 PM
InfamousRS's Avatar
Default Re: solid urathane mounts.... (Weston)
It was in the caulk section....you'll see it. There have several differnt tubes for several different applications.
Old Sep 20, 2002 | 07:31 AM
NA-GSR's Avatar
you can mix and match the prothane and es kits to cover all 5 mounts.
Old Sep 20, 2002 | 07:52 AM
ragejed's Avatar
Default Re: solid urathane mounts.... (NA-GSR)
If i got the Prothane upper ones...Will i notice a huge difference because I already have ES torque mounts
Old Sep 20, 2002 | 11:31 AM
sweet's Avatar
Default Re: solid urathane mounts.... (ragejed)
depending on what motor/chassis you have the dash, shifter, steering wheel and other things are going to vibrate more. i'm using only the lower 2 inserts for the rails and it's better but much more vibration.... damn glovebox. i gotta fix that.
later
Old Sep 20, 2002 | 02:11 PM
ragejed's Avatar
Default Re: solid urathane mounts.... (sweet)
I dont mind the virabtion. i prefer a engine that doesnt move over a virbator
Old Sep 20, 2002 | 08:59 PM
InfamousRS's Avatar
I have the lower 3 ES mounts in right now (well actually my motor isin't even in my car now ) and I bearly notice the vibration at all....Like said above, I would rather have vibration then my motor moving all over the place. I really want to do something to my top mounts to stiffen it up a little more. Are the prothane mounts just like the ES mount inserts? Where can I get them, and about how much are they?
Old Sep 20, 2002 | 09:15 PM
sweet's Avatar
oh i don't mind the vibration either. i'm into function before form so if it helps me go faster, handle better or last longer then i like it. that's where my time and $$ goes, always.
Old Sep 21, 2002 | 03:30 AM
ragejed's Avatar
Scracho
Nov 18, 2005 03:51 PM
Tire Monkey
May 2, 2004 05:23 PM
rondigs
Jul 21, 2003 06:26 PM
