Smoke from the engine bay?
Old Apr 2, 2003 | 12:17 PM
Turbo Powa's Avatar
Default Smoke from the engine bay?
I havent started up the teg for about 3 weeks. Today I tried to start it and the battery was dead so I jumped started the car with my civic. As it was warming up I heard it revving up and down from about 1000 rpm - 1500 rpm untill it warmed up. Then I noticed smoke coming from the exhaust manifold with a nastey smell. Is this a sign that I need to change exhaust manifold gaskets?
Old Apr 2, 2003 | 12:58 PM
Diego Boost's Avatar
Default Re: Smoke from the engine bay? (Panda EK)
Well, if you can see exhaust coming from the manifold then chances are that somthing needs to be fixed. Take it apart and check it out
Old Apr 2, 2003 | 01:03 PM
Turbo Powa's Avatar
Default Re: Smoke from the engine bay? (Diego Boost)
do you recommend just swaping the gasket to see if thats the problem?
Old Apr 3, 2003 | 05:25 AM
JimBlake's Avatar
First, you could check to make sure its not just some oil that leaked onto the outside of the manifold... I think if it were a leaky exhaust manifold gasket it would make some noise.
Old Apr 3, 2003 | 08:08 AM
Turbo Powa's Avatar
Default Re: Smoke from the engine bay? (JimBlake)
thats the thing. It sounded normal. I was only able to see alittle smoke seeping from the exhaust manifold.
Old Apr 3, 2003 | 08:15 AM
marltonteg's Avatar
sounds like it could just be a small oil leak...still a problem thats needs correcting...but not too serious
mecca858
Jun 18, 2015 09:23 AM
AmericanPie
Jan 1, 2011 01:56 PM
'90crxSI
Sep 14, 2008 05:38 PM
rustyeleio
Dec 26, 2007 11:58 PM
rustyeleio
Jan 28, 2003 08:39 PM
