slowed down
Old Mar 26, 2007 | 09:19 AM
VTEC_PRODUCTION's Avatar
Default slowed down
on my way to driving TO the bank today my car was running great and everything was fine...but when i got to leaving the bank i tried accelerating and it seriously took like 30 to get to 45 mph when i pushed the gas pedal all the way down...it runs fine i didnt get a check angine light or anything like that. it just started doing this and it never did before. i havent changed anything on the car either. anyone help?
Old Mar 26, 2007 | 09:42 AM
ziggz5011's Avatar
Default Re: slowed down (Acura_Integra_Type_R)
maybe your clutch goin out.
o yeah, how many miles does it have on it?
Old Mar 26, 2007 | 01:27 PM
WookinPaNub's Avatar
Try the fuel filter. If you can't get gas, you're not going to go fast.
Old Mar 26, 2007 | 01:38 PM
alexisthemovie's Avatar
forgot the handbrake?
Old Mar 26, 2007 | 01:43 PM
aaronISthrowed's Avatar
Default Re: (alexisthemovie)
Sparkplugs?
Bad gas?
Old Mar 26, 2007 | 04:19 PM
Default Re: (aaronISthrowed)
ebrake off just put premium gas in it...spark plugs maybe...but it sounds like it runs fine...i just dont know how it can go from running fine to running so slow...there is no pickup...and i just went through the drive through...never turned off the car...
Old Mar 26, 2007 | 04:20 PM
Default Re: (Acura_Integra_Type_R)
oh and the clutch is fine...there is no slippage...
Old Mar 26, 2007 | 05:26 PM
ArtificialSynapse's Avatar
Just drive a short distance after the car's rotors are cold and see if they heat up at all ( by placing your hand near the rotor, not on it! ) and see if it's warm, if it is, then your brakes are engaged.
Old Mar 26, 2007 | 05:46 PM
well if the brakes are engaged then when you lift off the throttle, the nose should dive and it would be pretty obvious.
Old Mar 26, 2007 | 06:22 PM
Does it still do this?
Old Mar 26, 2007 | 06:42 PM
there is absolutely nothing wrong with the brakes...i already checked...i just dont know why it is not accelerating...
Old Mar 26, 2007 | 07:14 PM
slammedNslowLS's Avatar
throw a 100 shot on there and see how that does LOL... j/k bro. it does sound like somethign with the brakes but you said you checked them. maybe you didnt let the e-brake all the way down... did you ever pull it at the bank?
Old Mar 27, 2007 | 06:52 AM
Default Re: (slammedNslowLS)
nope...i went throught the drive through and never pulled it...i rarely pull it anyway...i would know just how the car feels if the brakes were engaged when i drive it but in this case i know its not the brakes...
Old Mar 27, 2007 | 07:09 AM
beanMosheen's Avatar
Is your oil low? Vtec will not kick in with low oil.
Old Mar 27, 2007 | 07:15 AM
What does the rev feel like, is it perky and quick, or does it bog?
Old Mar 29, 2007 | 07:39 AM
Default Re: (ArtificialSynapse)
my oil is not low...vtec will kick...the engine runs fine and it will go through all the rpms but when i push the gas pedal all the way down it will speed up like im only pushing it about 1 inch down...
Flwr
Honda Civic (2006 - 2015)
21
Dec 18, 2007 03:25 PM
hockyguy18
Oct 22, 2007 11:54 AM
japspecjohn
Dec 9, 2003 07:03 AM
geminis2k
Nov 10, 2003 01:14 PM
TypeRuz
Sep 29, 2003 02:37 PM
