skunk2 IM install
There are a lot of people here who have installed the Skunk2 IM on their Integras. If you do a search, I'm sure you can get some helpful info and tips.
Good luck
Good luck
Search for threads by: neo1z (me), stinkytofu, bob-dc2, and skunk2nr. bob-dc2 has a comprehensive list, and I bitch enough about it to cover most problems.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TegLover4life »</TD></TR><TR><TD CLASS="quote">ok dont tell me to search i have already done that, i dont feel like reading through 30 different threads, just wanted to get some quick tips before i go to bed. Thanks though,
Thats why i said search for those created by us. They are relative to your question -and noone wants to write out a 10 page guide for you, when you can take YOUR time, not ours, to find the info that is sitting right there, waiting for you. Not trying to be a ***** - I am just telling you that you could look for it yourself, as opposed to waiting for us to answer. It would be easier on you. If you have a question on that material, then ask away.
</TD></TR></TABLE>Thats why i said search for those created by us. They are relative to your question -and noone wants to write out a 10 page guide for you, when you can take YOUR time, not ours, to find the info that is sitting right there, waiting for you. Not trying to be a ***** - I am just telling you that you could look for it yourself, as opposed to waiting for us to answer. It would be easier on you. If you have a question on that material, then ask away.
anyways.....its easy to install. Some quick tips would be to draw or write down a simple diagram of all the vacum lines so you know where they go. Or you can label them with a piece of tap or something. And your gonna need a new tb and IM gasket. Also, get a razor blade and scrape ALL the old gasket of the head. The install should be pretty straght forward.
you can use a gsr intake you just have to rotate it around (but the pcv hole is off). preferably youd use an ITR intake or LS if the diameter is adequete.
yes stock TB is fine. but it will create a whistling.
Guest
Posts: n/a
This link is for your lazy ***!!! http://www.jdmhondaparts.com/tech/sk2manifold/
