which size cat?
I'm about to buy a magnaflow cat for my DA but I'm not sure which size I should buy. I have a OBX header which has a 2" collector on it but my catback piping is 2.5". So would I want to get a 2" cat or a 2.5" cat?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by billabong »</TD></TR><TR><TD CLASS="quote">you need the cat with the 2inch collector nd a 2inch outlet
sounds like you need the direct fit for your DA. those 2.5" catbacks are usually crimped down to a 2" collector where it bolts up to the cat if they are designed for factory fit.
</TD></TR></TABLE>sounds like you need the direct fit for your DA. those 2.5" catbacks are usually crimped down to a 2" collector where it bolts up to the cat if they are designed for factory fit.
