shitty idel
Old Apr 23, 2005 | 07:48 PM
StrictlyJdm94's Avatar
Default shitty idel
i got a integra ls and when i start my car the idel is very high and stays very high for a maybe 3mins even when its really warm out..and once the car is warmed up and has been driving for a while the idel goes up to about 1500 rpms it stays there for a min and then drops down when car is stoped...any ideas???
Old Apr 23, 2005 | 08:12 PM
s2kdre's Avatar
Default Re: shitty idel (StrictlyJdm94)
try putting a new tps sensor on it.
Old Apr 23, 2005 | 08:56 PM
WhiteGSR95's Avatar
IAC maybe?
Old Apr 23, 2005 | 10:45 PM
apok's Avatar
It could be your car is trying to warm up? Mine idles at 1800 then slowly goes down to 750.
Old Apr 24, 2005 | 10:56 AM
riceball777's Avatar
what dont you turn the idea down
you know you can control how high you want the idea from the tb
Old Apr 24, 2005 | 12:26 PM
Default Re: shitty idel (riceball777)
how do i turn the idel down???
Old Apr 24, 2005 | 12:29 PM
SuzukaBlueAP2's Avatar
Did it just start doing so out of the blue one day?
It's possible the IACV is dirty and needs cleaning. I could clean that before diving in an adjusting the idle screw first.
Old Apr 24, 2005 | 12:40 PM
redDAinteg's Avatar
Default Re: shitty idel (ScreaminTeg)
your car looks so ricey. what kind of body kit is that ? invader or some ****.
Old Apr 24, 2005 | 01:07 PM
VtecAdvantage's Avatar
Default Re: shitty idel (redDAinteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redDAinteg &raquo;</TD></TR><TR><TD CLASS="quote">your car looks so ricey. what kind of body kit is that ? invader or some ****.</TD></TR></TABLE>
he didn't ask you to talk ****
Have you put any mods on it recently? because i've noticed a difference in idle when i put an AEM CAI. But if you should definetly check out ur IACV just to make sure its fine like ScreaminTeg said - but if thats fine try finding a walkthrough on how to tune ur idle down - its really not hard at all
Old Apr 24, 2005 | 05:45 PM
theres 2 ways to turbo the iead down
there a screw on the side of the tb
turn it right to turn the idea doen and turn it left to raise the idle
you can also use the screw that stops the butterflys.
Old Apr 25, 2005 | 07:28 AM
its a wings west front lip...wut your car look like saying my **** is ricey... i have that kit on my car 4 now i got other stuff i took off for the winter im waiting to put back oh. even with my car the way it is now i got compliments where ever i go...
Old Apr 25, 2005 | 07:29 AM
ill try that out thanks..
Old Apr 25, 2005 | 07:35 AM
hawjboi's Avatar
i agree with screaminteg...try to clean your iacv first and see how that is...most likey it is dirty...
Old Apr 25, 2005 | 08:37 AM
Default Re: (hawjboi)
any one have a pic of where the IACV is im cleaned some things jst wanna make sure its the right one....
Old Apr 25, 2005 | 08:46 AM
XSIWANNAB's Avatar
Default Re: (StrictlyJdm94)
illl tell you what everyone else is sayiing.your IAC.its anywhere from 220-300 dependeing where u go.i know its fucken expensive for a part that about 3 inches big
Old Apr 27, 2005 | 06:14 AM
Default Re: (XSIWANNAB)
wut does iac stand 4? and if anyone can send me a pic of where it is located that would be great and thanks 4 all your help
Old Apr 27, 2005 | 06:19 AM
n0 iNTegRiTY's Avatar
Whenever my idle gets high I unplug the battery and leave it be for about an hour. Then connect it again and leave the car runnin for about 5 minutes. Idle goes down
Old Apr 27, 2005 | 07:06 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StrictlyJdm94 &raquo;</TD></TR><TR><TD CLASS="quote">wut does iac stand 4? and if anyone can send me a pic of where it is located that would be great and thanks 4 all your help</TD></TR></TABLE>
IACV = Idle Air Control Valve
Think of it as an ECU controlled air leak. When the engine is cold and you start it, it allows more air to enter the engine. That's why it idle's higher on a cold start.
When you turn on an A/C compressor, it allows more air to enter to compensate for the extra load put on the engine.
ThatOneOG
Dec 7, 2008 12:30 PM
LSej1
May 26, 2007 12:20 PM
redrimsek9
Mar 4, 2004 05:49 AM
sleepyhamsterlx
17
Dec 15, 2003 02:55 PM
ILOVEGIRLS
Jul 31, 2002 02:43 PM
