Shift points w/ new wheels?
Old Apr 28, 2002 | 11:59 PM
Teg4e's Avatar
Default Shift points w/ new wheels?
How will my shift points be changed with 16" wheels vs. my current, stock 14"? In my LS, red-line in the gears goes as follows:
1st - 33 mph
2nd - 56
3rd - 84
4th - 110?
Does it increase at a ratio of 16:14, or X1.142, meaning 1st would be at 38 and 2nd at 64? Thanks in advance!
Old Apr 29, 2002 | 05:32 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Shift points w/ new wheels? (Teg4e)
Nothing will be affected because you should get 205/45-16 tires which have the same diameter as stock 195/60-14 tires.
Old Apr 29, 2002 | 08:15 AM
Weston's Avatar
Go by the tach, not the speedometer. Your optimal shift points will remain the same.
Old Apr 29, 2002 | 09:27 AM
Teg4e's Avatar
Default Re: Shift points w/ new wheels? (PatrickGSR94)
Oh, right, thanks for the help!
Old Apr 29, 2002 | 09:35 AM
shamoo's Avatar
Will you make something up for me please?
Yeah, your speedo will show the same speed no matter what size your wheels are. The speed sensor is on the tranny, so it's independent on how big or how fast the wheels are spinning.
Old Apr 29, 2002 | 11:53 AM
Integraholic's Avatar
Default Re: Shift points w/ new wheels? (shamoo)
correct, it does read off the tranny, thats why it is off when you get new larger wheels. It will still read the same MPH, but you ACTUAL speed will be a little faster. Ya just have to compensate in your head for it.
Dwn2ThaLastRoac
Acura TL, RL & ZDX
Jun 21, 2011 09:40 AM
Inisharu D
15
Mar 2, 2004 05:45 PM
ham
Feb 7, 2004 08:25 PM
vrrodri
Mar 7, 2003 03:17 PM
Teg4e
Apr 29, 2002 02:17 AM
