Shift Linkage pin
Old Oct 28, 2004 | 07:21 PM
Rod.'s Avatar
Default Shift Linkage pin
not trying to be hard headed or cheap. When you pop out the shift linkage pin they tell you not to use it again. What really happens if you reuse it. I couldnt find a thread on it. Thanks
Old Oct 28, 2004 | 07:26 PM
LSvtec03's Avatar
Default Re: Shift Linkage pin (redturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">What really happens if you reuse it.</TD></TR></TABLE>
nothing
Old Oct 28, 2004 | 07:27 PM
aznballer's Avatar
i think its not reusable that why, just get a new one
Old Oct 28, 2004 | 07:38 PM
Cjsls's Avatar
Default Re: (aznballer)
i've reused mine before. only cause it was sunday and the dealer was closed and i needed to fix the car.
Old Oct 28, 2004 | 08:10 PM
CRX_1.8T's Avatar
i think that they say that in case it breaks after re-use. maybe their way of not being responsible for old and worn out parts that may malfunction after being tinkered with too much. who knows?!
Old Oct 28, 2004 | 09:34 PM
Electron_LS-Vtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">not trying to be hard headed or cheap. When you pop out the shift linkage pin they tell you not to use it again. What really happens if you reuse it. I couldnt find a thread on it. Thanks</TD></TR></TABLE>
Take the old one with you and go to a hardware store...they sell compression pins in all differenent sizes for maybe 2 dollars....
Old Oct 28, 2004 | 10:30 PM
rovigian's Avatar
Default Re: (Cjsls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cjsls &raquo;</TD></TR><TR><TD CLASS="quote">i've reused mine before. only cause it was sunday and the dealer was closed and i needed to fix the car.</TD></TR></TABLE>
Me too, sundays are hell to work on a car for that reason.
Old Oct 29, 2004 | 12:23 AM
MyBigNut's Avatar
Default Re: (rovigian)
Dont worry yourself too hard, you can reuse it
Old Oct 29, 2004 | 05:11 AM
DontBlink's Avatar
Default Re: (MyBigNut)
i never bought a new one and i never seen or heard of one ever falling out, they dont slide back in you have to tap them in with a hammer, trust me its not going anywhere.
Old Oct 29, 2004 | 05:29 AM
AngelTeg's Avatar
Default Re: (DontBlink)
ya, you can reuse... just I know there are alot of people out there that mash them up pretty bad removing them, if that happens its kinda hard to re-use them.
but as everyone said, just pop it back in there...
-Mike
Old Oct 29, 2004 | 08:31 AM
hypa's Avatar
Default Re: (AngelTeg)
If you're gentle taking it out, you can easily reuse it. Be sure to install the safety spring that surrounds the pin though, as that's the most important part.
Old Oct 31, 2004 | 08:18 AM
Gsr_Hybrid_theory's Avatar
Default Re: (hypa)
uchk if you buy a new pin you WILL kill yourself trying to put it in... holy christ i wanted to throw the fkin thing away... my god... what a pain... esp 2-3" above me...
Old Oct 31, 2004 | 09:46 AM
s2kkid's Avatar
Default Re: (hypa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hypa &raquo;</TD></TR><TR><TD CLASS="quote">If you're gentle taking it out, you can easily reuse it. Be sure to install the safety spring that surrounds the pin though, as that's the most important part.</TD></TR></TABLE>
****... HOW?
i tapped with a hammer forever, I finally got pissed off bad enough and put an air hammer on it, and it got it out....
Old Oct 31, 2004 | 10:02 AM
Rod.'s Avatar
Default Re: (vtecluder97)
a punch and hammer for taking it out
Old Oct 31, 2004 | 10:33 AM
blusmke's Avatar
Default Re: (redturbocivic)
or you could just use a bolt. I've reused every time I have done it never had a problem.
Old Oct 31, 2004 | 10:56 AM
Rod.'s Avatar
Default Re: (blusmke)
I just popped it back in and it shifts fine. THanks everyone
Old Oct 31, 2004 | 11:19 AM
blusmke's Avatar
Default Re: Shift Linkage pin (Electron_LS-Vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Electron_LS-Vtec &raquo;</TD></TR><TR><TD CLASS="quote">
Take the old one with you and go to a hardware store...they sell compression pins in all differenent sizes for maybe 2 dollars.... </TD></TR></TABLE>
Just put the old one in and save your two dollars for a big gulp from 7-11.
Old Nov 1, 2004 | 10:36 AM
hypa's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecluder97 &raquo;</TD></TR><TR><TD CLASS="quote">i tapped with a hammer forever, I finally got pissed off bad enough and put an air hammer on it, and it got it out....</TD></TR></TABLE>
AIR HAMMER!
woot.
It's the best way to do it. Just be sure you use the proper sized punch as not to mushroom the pin. To install, I gently tighten it in a vice grip, and press it in as far as I can, then use the air hammer again to tap it in all the way.
Old Nov 1, 2004 | 11:32 AM
PlastikOwl
Guest
Posts: n/a
Default Re: (hypa)
I've always reused the pin.
rjc89sir
Sep 17, 2007 02:15 AM
spiderhatch
Apr 27, 2007 02:28 PM
Hondageek
Honda S2000
May 12, 2006 10:46 PM
atsyuo
Aug 24, 2005 11:43 AM
rasinhell
Jan 19, 2005 07:23 PM
