Shift linkage. Need info
I've searched around and was unable to find a solid answer. Will a dc2/dc4 integra shift linkage fit my 91 da9? I'm replacing my clutch and flywheel soon, and I would like to know if this linkage is a direct bolt on. I will be replacing my transmission as well with an obd1 Ls cable tranny. I Appreciate the help.
b series "swap" linkages can mean anything. they are particular to the chassis you are using.
b swap linkages for a 92 95 civic fit 92 95 civic/94 01 teg/and 96 00 civic with b swaps.
Crx b swap linkages fit crx
ETC
you need the linkages that fit the car
ETC
