shift light
Old Sep 8, 2003 | 06:48 PM
spoonitr529's Avatar
Default shift light
how do i install my new shift light? i dont feel like screwing this up...figured you guys could help
Old Sep 8, 2003 | 10:28 PM
Steve04SVT's Avatar
Default Re: shift light (spoonitr529)
Well, I' assuming you're talking about hooking it up electrically speaking. Just follow the directions. You should have three wires, 1 red for 12volt accessory/switch, 1 black for ground. and 1 green for tach signal. The wires just need to be spliced into the corresponding wires within you car's wiring system. If you're not electrically inclined, then I would suggest letting someone who knows electrical do it. It will save you time and worry in the long run.
Old Sep 9, 2003 | 02:53 AM
Loveless's Avatar
Default Re: shift light (Steve00GSR)
can I install more than one shift light?
Old Sep 9, 2003 | 04:28 AM
Charlie Moua's Avatar
Default Re: shift light (Loveless)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loveless &raquo;</TD></TR><TR><TD CLASS="quote">can I install more than one shift light?</TD></TR></TABLE>
care to explain why?
there are little gadgets that people have made for multiple shift light points. they work and are compact so it doesn't look like you have 3 shift lights sitting on your vent or cluster.. LOL
Old Sep 9, 2003 | 09:40 AM
Loveless's Avatar
Default Re: shift light (Charlie Moua)
well I want one to remind me around 3k and another at 6.5k
care to show me where I can find more info about that?
Old Sep 9, 2003 | 11:13 AM
Full Race EG's Avatar
i have an autometer mini shift light. i also bought and rpm activated switch. 3 wires: Red - power / Black - Ground / Green - Tach signal. the green wire connects to the blue wire with silve dots behind the tach in the wiring harness on your gauge cluster. splice into that 1 then get an rpm pill for the point you want to shift at. if you want to i guess you could get 2 rpm activated switches and 2 shift lights and double splice the tach wire and put 2 different rpm pills in them. i dont know why you would want it to light up at that low of rpm anyway
MonkeyPuzzle
47
Nov 11, 2014 12:03 AM
ej1love
May 26, 2009 04:22 AM
dturbo
Oct 23, 2005 10:50 PM
