setup for my build
Old May 23, 2008 | 07:23 PM
seldon's Avatar
Default setup for my build
hey i'm new to the site, i'm building an ls/vtec for my integra, just want some thoughts on my parts selection, i got a b18b block, going with ctr pistons, arp rod bolts, now for the head i'm going with a type r head with skunk2 pro series 2 cams and high comp skunk2 valves, titanium retainers, skunk2 throttle body (70 mm) and intake manifold, 340cc injectors.. thats how i plan to build the engine, it's an all motor build, any opinions? thanks
Old May 23, 2008 | 07:39 PM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: setup for my build (seldon)
What crank and rods are you using? you should use acl rod and main bearings! What header id suggest a hytech header if on a budget get the big tube replica from ebay like i did you should make good power with that header and your set up! get a hondata s100 at least for tuning you can go with the free crome program as well but its up to you, what kind/ size exhaust id recomend at least 2.5 inch pipping.
Old May 23, 2008 | 07:42 PM
seldon's Avatar
ya i got acl bearings, for header i got a dc header 4-1 and i'll be upgrading the exhaust to 2.5", wasn't sure which ecu to use
Old May 23, 2008 | 07:46 PM
seldon's Avatar
Default Re: (seldon)
oh and the crank and rods i plan to leave stock, maybe get the rods shotpeened
b20vtecGSR
15
Feb 25, 2017 09:01 AM
LSD_Rob
Mar 30, 2012 06:31 AM
ACTION JACTION
44
May 8, 2009 04:38 PM
ACTION JACTION
Mar 21, 2009 01:39 AM
-faded-
Jul 30, 2004 04:00 PM
