sensor ontop of IM
Old Aug 7, 2005 | 02:50 AM
civickiller's Avatar
Default sensor ontop of IM
i just got a ls motor, the head says 95 but the dist is obd2 and the injectors look obd2 and the back of the intake mani says p75. there is a sensor a couple inches after the tb on the manifold itself. there is a plug with yel/blk and red/yel wires coming off of it, so only 2 wires. and there is a hose coming off of it. the only numbers on it were 136200-1350 and under that it said pcs7.
anybody help me with what sensor this is ?
Old Aug 7, 2005 | 03:03 AM
Default Re: sensor ontop of IM (civickiller)
here is a pic of a ls intake mani with the sensor circled in red.
Modified by civickiller at 12:16 PM 8/7/2005
Old Aug 7, 2005 | 04:09 AM
mugenracer's Avatar
thats the MAP sensor
Old Aug 7, 2005 | 08:16 AM
Default Re: (mugenracer)
isnt the map sensor usually 3 wires ? this only has 2 wires coming out of it. if it is the map sensor, what 2 of the 3 wires on my stock car should i wire it into to make it work because i own a ef civic and im putting this motor in there. or because its only 2 wires, i need to use my stock map sensor ?
Old Aug 7, 2005 | 09:08 AM
DANG YO's Avatar
Default Re: (civickiller)
wow shows how much you guys know.. the map sensor is on top of the throttle body. the sensor circle is your EVAP purge sylinoid. if you are staying obd1 then just leave the sensor there and dont worry about plugging it up or hooking the 2 hoses up seeing is that only obd2 ecu's read that sensor.
Old Aug 7, 2005 | 09:26 AM
Yambor's Avatar
Default Re: (dc2kid)
here, now no more confusion, and the MAP sensor is on the TB!
Info on the EVAP Solenoid!
Evaporative Emission (EVAP) Purge Control Solenoid Valve
When the engine coolant temperature is above 154 °F (68 °C) and the air conditioner on, the ECM/PCM controls the EVAP purge control solenoid valve which controls vacuum to the EVAP purge control canister.
lowintheo
May 29, 2009 05:44 PM
Soccerking3000
Apr 28, 2007 08:05 PM
hondaeg8
Jun 22, 2005 03:03 PM
asianspeed
Aug 11, 2003 07:23 PM
