Safe to wash engine?
Hi all,
I would like to know if it is safe to spray water and wash the engine of an integra assuming all parts of the engine are stock. Would it cause any rustings and malfunctions to the components of the engine? Thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94TurboGSR »</TD></TR><TR><TD CLASS="quote">You're going to want to cover the filter and the distributor.</TD></TR></TABLE>
and the ignition
and the ignition
Dont need to cover nothing up, just make sure the spark plugs covers are on all the way and if you have a open element filter, then cover that. otherwise spray when the engine is cool and then wash and drive immediately so the engine will heat up and dry the engine. Also use low pressure, if using garden hose, spray lightly.
Cover all the elec. components up. Spray engine bay with GUNK engine degreaser, let that set for 10 mins or so, then hose(gentle spray) everything off real good. Then dry with towels.
-Aaron who needs to clean his FILTHY FILTHY engine bay...
Modified by SilverB18C1 at 6:16 PM 8/31/2003
My boyfriend(EJseven) did this to his civic today, he covered up the battery, dizzy, alternator, and plugs. As soon as he was done he took it for a 20 min. drive, everything was dry when he got back home.
i just cover my valve cover, distributor, and timing belt (no upper cover cuz of gears)...i just use this sweet degreaser from work, it does an awesome job...i also dont bother drying it, i just drive it afterwards-i figure it will steam clean itself.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wild0ne21 »</TD></TR><TR><TD CLASS="quote">can you use that simple green on the type r valve cover with out it stripping the red</TD></TR></TABLE>
I did once, no problems at all.
Although I wouldn't do it to often as I heard its pretty strong stuff and after repeated uses it may strip paint.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95VXFRANK »</TD></TR><TR><TD CLASS="quote">if you plan on using simple green to clean the valve cover, make sure to dilute it with water as using it by itself will after a while begin to strip the red off</TD></TR></TABLE>
thanks for the help....so what like half and half?
im sorry off topic but, "what is the black boxy thing called in the picture of the engine bay above that has the spark plug wires comming out of it into the spark plug cover? yea i was advised to change mine due to what happened a few weeks ago... thx!!!
try using those high presured keyboard cleaner **** to spray the spots you want clean.. or spray the whole engine without being scared you might rust somthing.. and if some spots are left over try using a rag and a bit a water =]
Yap.. Simple Green
I used garbage bags to cover the battery, alternator and I avoided spraying the distrib.
Spray car and go for a drive. Outcome:
Comes in handy for other places too:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redlinex »</TD></TR><TR><TD CLASS="quote"> [img][/img]
im sorry off topic but, "what is the black boxy thing called in the picture of the engine bay above that has the spark plug wires comming out of it into the spark plug cover? yea i was advised to change mine due to what happened a few weeks ago... thx!!!</TD></TR></TABLE>
thats the distributor dude
oh well...
