???s about Integras.
Old Nov 15, 2003 | 02:01 PM
DownSouth's Avatar
Default ???s about Integras.
So, Im an RX7 guy, always have been. I know them in and out.
I know none of the lingo associated with these cars however. Can someone give me some pointers on the different models, what seperates em, etc?
Thanks!
Old Nov 15, 2003 | 02:03 PM
JDM_Honda_Fiend's Avatar
Default Re: ???s about Integras. (DownSouth)
Shouldn't this post be in the RSX/EP3 forum?
b18c_power's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DownSouth &raquo;</TD></TR><TR><TD CLASS="quote">So, Im an RX7 guy, always have been. I know them in and out.
Thanks!
Here!
Old Nov 15, 2003 | 04:32 PM
Hites
Guest
Posts: n/a
Thanks!
ill help you out instead of being a ********.
teg = integra
b18b = 140 hp base model non-vtec engine
rs = low-base model, no luxuries but light weight
ls = middle-base model (and most common), fits between the rs and the gs/se
gs/se = high-base model, basically a gsr (leather seats, alloy rims) without the b18c
gsr = next step above the rs/ls/gs/se integras with a b18c engine
b18c = 170 hp vtec engine found in the gsr
b18c5 = 200 hp vtec engine found in the type r
ls/vtec = a b18b block mated with a b18c or b16a civic head (not made by honda)
b20/vtec = a b20b or b20z crv block mated to a b18c or b16a head (also not made by honda)
pretty much any b-series engine can fit into any honda or acura that came stock with a b-series engine. hope this helps you out somewhat
Old Nov 15, 2003 | 04:55 PM
neo1z's Avatar
Default Re: ???s about Integras. (Hites)
Go to http://www.team-integra.net and look around. Youll learn alot - especially in the articles area.
Old Nov 15, 2003 | 05:57 PM
The HamsterBall's Avatar
Default Re: ???s about Integras. (JDM_Honda_Fiend)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Honda_Fiend &raquo;</TD></TR><TR><TD CLASS="quote">Shouldn't this post be in the RSX/EP3 forum?</TD></TR></TABLE>
why the hell would it belong in the RSX/EPshit forum?
Old Nov 15, 2003 | 06:27 PM
projectTeG's Avatar
he said <U>RX7</U> not rsx
Old Nov 15, 2003 | 06:28 PM
P1mpSlap's Avatar
Default Re: ???s about Integras. (neo1z)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neo1z &raquo;</TD></TR><TR><TD CLASS="quote">Go to http://www.team-integra.net and look around. Youll learn alot - especially in the articles area.</TD></TR></TABLE>
We need to establish some sort of n00b faq. lol
RX7 eh? If I had me an FD3S i'd never look back on my DC2.
Old Nov 15, 2003 | 07:07 PM
Default Re: ???s about Integras. (projectTeG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG &raquo;</TD></TR><TR><TD CLASS="quote">
he said <U>RX7</U> not rsx</TD></TR></TABLE>
Lol my bad for some reason i saw it as rsx.. Time to get a bigger screen for my laptop
correction on your specs hites...
usdm b18c5= 190hp and the jdm b18c5 is 200hp
ls/b20-vtec are hybrid engines that utilize b18a/b(ls) block or b20b/z(crv) block with a b16, gsr, or type r head
And B-series motors will fit in most Honda/Acura with mount kits even if it doesn't come with a stock B-series engine
Cheers
Modified by JDM_Honda_Fiend at 5:02 AM 11/16/2003
Old Nov 15, 2003 | 07:51 PM
wanna b R's Avatar
heheheehHAHAHAHAA
Old Nov 15, 2003 | 09:05 PM
DownSouth's Avatar
Default Re: ???s about Integras. (b18c_power)
Hey that search function works great! Thanks for pointing it out to me!
I put in b18_cpower and hit search, it came back and said "***!"
Ill have to remember that one.
Old Nov 16, 2003 | 05:17 AM
Hites
Guest
Posts: n/a
Cheers </TD></TR></TABLE>
correction on your specs...
no such thing as a jdm b18c5 200 hp type r engine; its just a b18c without the final number
what the hell was wrong with my ls/vtec and b20/vtec explanations? i didnt include the shittier b18a? or that i didnt specify that the head had to be dohc?
yes a b-series engine will fit into almost any honda vehicle, but you dont have to buy mount kits if you put it into another b-series engine, which would make it virtually a basic bolt-IN.
Old Nov 16, 2003 | 05:36 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hites &raquo;</TD></TR><TR><TD CLASS="quote">
yes a b-series engine will fit into almost any honda vehicle, but you dont have to buy mount kits if you put it into another b-series engine, which would make it virtually a basic bolt-IN.</TD></TR></TABLE>
True the JDM type-r engine is a JDM B18c but my correction was on your horsepower specs. The difference between the USDM and the JDM motors
the b18a/b block have very little differences.. one is not shittier than the other and one doesn't make more displacement than the other. The main difference is the placement of the sensors on the motor.
True if your car came stock with a b-series motor, you can swap a different b-series motor in as a direct drop in with minor modifications with the wiring (ex. obdo-obd1, obd1-0bd2, obd2-obd1)
What i meant to say was that a motor mount kit can be bought if you wanted to drop in a b-series motor into your car if it didn't come stock with a b-series motor. (ex. civics not including SI)
Old Nov 16, 2003 | 05:47 AM
vain's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Honda_Fiend &raquo;</TD></TR><TR><TD CLASS="quote">correction on your specs hites...
Modified by JDM_Honda_Fiend at 5:02 AM 11/16/2003</TD></TR></TABLE>
usdm b18c5 = 195hp :D
Old Nov 16, 2003 | 05:59 AM
Default Re: ???s about Integras. (vain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vain &raquo;</TD></TR><TR><TD CLASS="quote">
usdm b18c5 = 195hp :D </TD></TR></TABLE>
ah you are right bro
ReV LiMiT
Nov 2, 2006 09:53 AM
quick
Honda Motorcycles
16
Oct 9, 2006 03:08 PM
B18C R Spec
Jan 24, 2006 03:26 PM
Jon V
Feb 12, 2005 02:51 PM
B16A2-EM1
10
May 13, 2003 08:13 AM
