Rusty Bolts!
Old Jul 22, 2003 | 02:22 PM
B18CYAAA's Avatar
Default Rusty Bolts!
My heat shield as well as many of the bolts that connect my header to the cat have been a victim of oxidization. Now they are going to take alot of wrenching to get them off. I heard someone on here used a gel/substance and that helped loosen them for the following day when the bolts were removed. Does anyone know what this, where you can get it or how much it costs?
Modified by B18CYAAA at 11:39 PM 7/22/2003
Old Jul 22, 2003 | 03:04 PM
B18CYAAA's Avatar
Default Re: Rusty Bolts! (B18CYAAA)
Anybody?
Old Jul 22, 2003 | 03:11 PM
Echo7847's Avatar
Liquid Wrench, PB Blaster...?
Old Jul 24, 2003 | 12:31 AM
tegmech's Avatar
I just pulled of the cat back exaust on a 95 ls and the bolts were completly oxidized on. I first cleaned the bolts off with a wire brush. Then i used WD40, then Liquid Wrench with no luck. I took a propane torch and heated up the nut on the bolt for about two min. and it came off with not much effort.
Old Jul 24, 2003 | 01:56 AM
IntEGNYC's Avatar
Default Re: (tegmech)
yeah, the cleaning usually will loosen the bolts to some extent but the heat will help expand and further help your efforts.
Old Jul 24, 2003 | 05:12 AM
Rory Breaker's Avatar
Default Re: (IntEGNYC)
Some WD40/PB Blaster and a long pipe slid over the ratchet will get them off with little effort.
Old Jul 24, 2003 | 06:02 AM
lustedp's Avatar
B'laster
Old Jul 24, 2003 | 06:56 AM
ltho1998's Avatar
There's this stuff from 3M that dissolves rust as well as protects from it in the future and acts as a penetrating fluid. I forgot the name of it and i'm not at home to grab the can, but anyway, works wonders.
Old Jul 24, 2003 | 08:13 AM
opi's Avatar
opi
Default Re: Rusty Bolts! (ltho1998)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ltho1998 &raquo;</TD></TR><TR><TD CLASS="quote">There's this stuff from 3M that dissolves rust as well as protects from it in the future and acts as a penetrating fluid. I forgot the name of it and i'm not at home to grab the can, but anyway, works wonders.</TD></TR></TABLE>
let us know when you find the name of this stuff, sounds good...
Old Jul 24, 2003 | 08:28 AM
ltho1998's Avatar
Default Re: Rusty Bolts! (opi)
It's called 5-way penetrant from 3M.
Here's a datasheet on it, as for where you pick it up though is beyond me. I got it from my gf's work and she works at a plastic supply company.
http://products3.3m.com/catalo...m_3_0
20CiviC02Si
Mar 30, 2015 08:03 PM
civiccoupe94
34
Nov 17, 2005 08:15 AM
oMek
May 6, 2004 01:06 PM
94B18B1Teg
Mar 15, 2004 11:05 AM
