Running With No belts a Problem??
Old Mar 2, 2003 | 07:30 AM
integranator's Avatar
Default Running With No belts a Problem??
A while ago i decided on taking the power steering belt off so i could can some more hp (I know i know) And now i can't find the belt, so i just run with out it. Also, a while back-- maybe december-- I was doing some check ups on my teg, and saw my ac belt was shredded, and didn't have time to get a new belt put on, so i just cut it off. Is there any problems with out running the ac belt, or the powersteering belt for a long period of time??
Old Mar 2, 2003 | 07:38 AM
Rory Breaker's Avatar
Default Re: Running With No belts a Problem?? (integranator)
I ran no AC belt for a long time, and continue to do so. Over the past 1.5yrs, Ive had AC for maybe 2 months I didnt notice any adverse affects.
As for PS, its not the recommended way to remove the PS since the fluid still should be distributed, but a lot of people have ran it for a long time...eventually, you will run into a problem though and should convert to manual steering if thats what you prefer.
Old Mar 2, 2003 | 04:08 PM
real9999's Avatar
Default Re: Running With No belts a Problem?? (newgsrdriver)
I ran without a power steering belt for close to a year. Some of my ps hoses are swollen near the ends, but none of them are leaking. And yes, Honda fluid. There MIGHT be a link...
Tom
Old Mar 2, 2003 | 06:38 PM
Rtzx9r's Avatar
GDD 1%
Default Re: Running With No belts a Problem?? (real9999)
those who do not use the A/C at least once a month over time develop refrigerant leaks and thus no more a/c.
There is minimal resistance on the car when the belt is on, unless the clutch is engaged because it is just acting as a pulley. (a/c clutch)
Old Mar 2, 2003 | 06:47 PM
Armed Ferret's Avatar
Default Re: Running With No belts a Problem?? (Rtzx9r)
i plan on eventually removing the a/c system altogether (FFGeoff goodness ); as of yesterday i now have a manual steering rack swapped in and nearly all the components (save for a couple lengths of p/s line that are sandwiched down in there pretty tight) removed--including p/s pump, rack, and reservoir, along with, as i said, most of the lines.
i've never enjoyed my car more.
Old Mar 3, 2003 | 10:55 PM
deepgreengsr's Avatar
Default Re: Running With No belts a Problem?? (SlowRedTeg)
take the ps and ac out. They are heavy. And they are in the wrong place... the front.
nick105
Honda Civic (2001 - 2005)
Jul 31, 2013 10:18 PM
Integra4lyfe069
May 26, 2010 06:07 PM
D50boy
Jan 14, 2005 12:54 PM
VTEC_JUNkie
Aug 24, 2003 04:45 AM
PorscheGT2
Dec 18, 2001 01:17 PM
