Rubber or Polyurathane?
Old Feb 27, 2012 | 01:09 PM
Da_1991's Avatar
Default Rubber or Polyurathane?
Not too sure what to get. Of course I am leaning towards cheaper, rubber. Plus this is just my DD. Thoughts? Thanks!
Old Feb 27, 2012 | 01:14 PM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
Default Re: Rubber or Polyurathane?
For what? Bushings I assume, but which bushing?
Poly is stiffer and last longer but does tend to be noisy
Old Feb 27, 2012 | 01:19 PM
Da_1991's Avatar
Oh yes bushing. Was looking into poly. Do you know how much more it is for poly?
Old Feb 27, 2012 | 01:28 PM
Shane_00integra's Avatar
Urethane for a dd
Old Feb 27, 2012 | 01:29 PM
vtaker's Avatar
Is the suspension all stock?
Old Feb 27, 2012 | 01:30 PM
phunhaus's Avatar
Poly doesn't last longer.
Old Feb 27, 2012 | 01:54 PM
GagnarTheUnruly's Avatar
wtf misinformation alert...
Poly is less durable in general (although quality varies) and can be made stiff or hard just as rubber can. PIC bushings are 85A durometer rated which is higher than many poly bushings on the market, and it's less harsh for a given durometer rating.
IMO the only advantage of poly is price, although some people prefer it because it lets arms pivot more freely.
Old Feb 27, 2012 | 02:03 PM
hustle4rxj's Avatar
Do you want less or more movement/noise. That would be the answer/question- rubber if dd
Old Feb 27, 2012 | 02:53 PM
bnetkillzone's Avatar
It depends. OEM or regular rubber, or hard rubber like PIC or Hardrace?
Hard Rubber
Old Feb 27, 2012 | 03:00 PM
B20ztek's Avatar
I always upgrade to polyurethane because I tend to be hard on my cars, less movement= less broken axles lol
Old Feb 27, 2012 | 03:32 PM
Da_1991's Avatar
I never saw the hard rubbers before, but I will look into those now. Any other brands besides hardrace and PIC?
Old Feb 27, 2012 | 03:35 PM
phunhaus's Avatar
For a DA your option might be limited to just Hardrace.
Old Feb 27, 2012 | 03:41 PM
Da_1991's Avatar
Oh dont mind the name. I have a DB 91 also...but I don't think that would make much of a difference. I still might just get regular rubber if I can't find any.
Old Feb 27, 2012 | 04:10 PM
Da_1991's Avatar
Nah lowered on skunk2's
Old Feb 27, 2012 | 05:03 PM
91_Civic_hybrid's Avatar
Full energy suspension on my 91 hatch. Torqued everything to spec by honda manual. Loading the suspension when needed to and I didn't have a single issue. Lowered on neu-speed coilover n tokico struts with a b series swap. Proper installation is important
Old Feb 28, 2012 | 10:03 AM
phunhaus's Avatar
There's not really a proper installation technique for urethane outside of greasing where applicable. Since the urethane isn't bonded to either the inner or outer sleeves you don't have to load the suspension before torquing down.
SlimBB4
Feb 13, 2010 07:09 AM
fastboy559
13
May 20, 2009 05:05 PM
redboost10
Jun 7, 2007 11:45 AM
dubnine
Suspension & Brakes
Mar 14, 2007 02:23 PM
wuhungsixxx
Oct 5, 2001 11:03 AM
