rubber or poly ingalls?
im trying to decide to get rubber or poly camber kit. iv'e done some searching and there doesn't seem to be a easy answer.
i found this on one site...
"Ingalls designed the RUBBER bushing kits for the "street" use only vehicle. They provide a more factory like ride and don't need to be lubricated but they won't give you that "tight" suspension feel. "
if they both have been reported to sqeek why wouldn't i want to go with the "tighter" suspension feel.
thanks eveyone,
Neil
thanks eveyone,
Neil
does anyone know if you can replace the ingalls bushings wiht something else?
i have a set w/ poly bushings but wanted to go w/ solid/spherical but wasnt sure if kits made for stock applications would work w/ ingalls.
