Rough idling... help please
Old Nov 17, 2006 | 09:04 AM
8YourV8's Avatar
Default Rough idling... help please
so i just bought a '94 integra with a lot of goodies under the hood... the car's idle jumps up and down, from around 500 rpm to 1000 rpm (as if it had cams in it, which it doesn't) the idle control/throttle body is fine and the check engine light isn't on. Im thinking maybe it's the fuel injectors? (1,000cc injectors). the car's tuned properly with a t3/t4 at 10psi on an otherwise stock GSR motor pushing around 330 WHP... im thinking it's the injectors causing the idle to jump like that... looking for your imput, thanks.
Old Nov 17, 2006 | 09:44 AM
cranny's Avatar
24.224.233.247
Default Re: Rough idling... help please (unpainted)
as long as the A/F ratio is correct across the board i cant see it being injectors. but they are big , lol , bigger than ive played with , lol. sure its not your high idle valve? plastic screw adjustment?
Old Nov 17, 2006 | 09:47 AM
95 integra's Avatar
1000cc injectors for 330whp? My guess is engine management problems. Could be the base idle is set too low, could be a bad IACV (not sure how you "checked" it), could be a bad ecu tune.
Like cranny said, check out the FITV on the underside of the TB as well. You'll have to take it apart (theres a how to somewhere....do a search).
Old Nov 17, 2006 | 11:51 AM
96twofourty's Avatar
How do the plugs look?
Old Nov 17, 2006 | 11:57 AM
jdminspiredDB8's Avatar
Default Re: Rough idling... help please (96twofourty)
check your FITV
https://honda-tech.com/zerothread?id=1564019
civickiller
May 12, 2010 02:10 PM
cbustuner
Mar 24, 2008 10:38 PM
boostedh22a
May 6, 2006 05:58 PM
JAY
Mar 25, 2006 07:31 PM
vtecmissle
Feb 19, 2006 11:47 PM
