rim bolt pattern????
Old Mar 20, 2003 | 04:46 PM
BlackOut21's Avatar
Default rim bolt pattern????
I did a search but didn't come up with anything. Can anyone tell me will a set of rims with a 4/100/114.3 bolt pattern work on a 1995 integra gsr? Thanks
Old Mar 20, 2003 | 04:49 PM
tC_Dragon's Avatar
Default Re: rim bolt pattern???? (BlackOut21)
well sounds like that rim will fit either a 4x100 or 4x114.3 if that is the case, then i don't see why it wouldnt fit. All tegs and civics i think have 4x100 lug pattern (excl. Type R)
Old Mar 20, 2003 | 06:20 PM
mr.beeks's Avatar
Default Re: rim bolt pattern???? (pdcdragon)
now the only question is
what is the offset
best fit is between 38mm or 40mm
Old Mar 22, 2003 | 11:23 PM
ek4ek9's Avatar
the JDM 96 ITR come with 4x114.3 bolt pattern with a +50 offset
the JDM 98 up ITR come with the 5x114.3, CTR uses the same bolt pattern
most civic and integra in US use 4x100 and if you are thinking of doing a conversion / fitment make sure its the right size rims for the right bolt pattern.
i have the **** now for trying to fit the 96 ITR rims into my ek4 civic. and the only way to solve this would be to contact H&R to fit out a spacer conversion set...that what i heard, i have not done that but if anyone know of any, let me know how to work out the problem. otherwise i would have to sell my jdm 1996 ITR rims.
djs87
Apr 28, 2008 05:54 PM
95~hatch
Honda Fit
Mar 25, 2007 01:34 PM
tiennhuynh
Dec 27, 2006 10:21 PM
Kgb
Nov 10, 2005 03:22 PM
cilvia
Jun 12, 2005 05:46 PM
