Ride Height issues.. help
Old Mar 15, 2006 | 09:14 PM
watsvtecEK's Avatar
Default Ride Height issues.. help
I have eibach sportlines, and tokico blues. My passenger side is higher then my drivers side! and not just a little, its noticeable. I bought the car like this about 8 months ago and it is really starting to bug me now.
The only thing i can think of is that the idiots who installed the springs and struts put the back springs on the passenger side, and the front springs on the driver side. In result making the passenger side higher. Is there any markings on the springs so i can see if this happened? and could anything else make one side higher then the other?
Old Mar 15, 2006 | 09:43 PM
Deano_D aka
Default Re: Ride Height issues.. help (D 2da A9)
This is actually normal for the car to sit alittle higher on one side with springs.
Old Mar 15, 2006 | 09:55 PM
SlammedDC2teg's Avatar
Default Re: Ride Height issues.. help (Deano_D)
Also you add more weight to one side when you drive. I would just replace them with some ground controls.
Old Mar 15, 2006 | 09:58 PM
LSintegra's Avatar
depends how much higher the passenger side is? i have the same suspension setup as you, and the passenger side is slightly higher, but barely. however enough to notice it from a distance.
Old Mar 15, 2006 | 10:02 PM
watsvtecEK's Avatar
Default Re: Ride Height issues.. help (SlammedDC2teg)
yes the driver side sits a little lower. But i was on a flat surface and i decided to see how much the difference was. So on the passenger side i could stick a credit card between the tire and wheel well. and on the drivers side i could not fit it. i am thinking maybe it is about 1/4 inch difference maybe more.
Old Mar 15, 2006 | 10:03 PM
watsvtecEK's Avatar
Yes it is noticeable. I was thinking another set of springs. With more of a drop.
Old Mar 15, 2006 | 10:08 PM
LSintegra's Avatar
try looking at Goldline springs, it should drop your da about 2.25''.
Old Mar 16, 2006 | 12:53 AM
TunerN00b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D 2da A9 &raquo;</TD></TR><TR><TD CLASS="quote">I have eibach sportlines, and tokico blues. My passenger side is higher then my drivers side! and not just a little, its noticeable. I bought the car like this about 8 months ago and it is really starting to bug me now.
The only thing i can think of is that the idiots who installed the springs and struts put the back springs on the passenger side, and the front springs on the driver side. In result making the passenger side higher. Is there any markings on the springs so i can see if this happened? and could anything else make one side higher then the other?</TD></TR></TABLE>
The passenger side being higher is normal. It is higher with stock springs, as well, its just much harder to tell with the stock 4" fender gap. The driver's side is heavier, because of the offset engine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlammedDC2teg &raquo;</TD></TR><TR><TD CLASS="quote">Also you add more weight to one side when you drive. I would just replace them with some ground controls.</TD></TR></TABLE>
I love my Ground Controls. However, even though you could use them to compensate for the heavier side of the car, doing so would hurt handling. If you "raised" the heavier side of the car until the body was level, you'd seriously be throwing the corner weights off, even further than they would be with all the springs set at the same place.
Old Mar 16, 2006 | 01:12 AM
foam's Avatar
Yeah it's normal.. it kind of bothers me sometimes though when I look at my car haha...
Old Mar 16, 2006 | 05:04 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
If he had adjustable height coilovers and had the corner weights dialed in correctly, I'm thinking the car should sit pretty close to level side-to-side. If the driver side is lower now, it will be even lower with the driver in the car, which would NOT be good for any sort of balance while driving.
grandtheftlunchbox
Suspension & Brakes
12
May 26, 2010 10:56 AM
SlammedEH3
Suspension & Brakes
Feb 19, 2009 12:52 PM
shadow103rd
12
Oct 23, 2003 04:38 PM
whytexbuddah
Mar 17, 2003 07:40 PM
