reverse lights stoped working
Old Dec 4, 2006 | 11:40 AM
NAmodified's Avatar
Default reverse lights stoped working
my reverse lights stopped working out of the blue... Any one have any ideas, and no the bulbs arent blown.
Old Dec 4, 2006 | 12:54 PM
PrinceAli132's Avatar
Default Re: reverse lights stoped working (NAmodified)
Check the fuses.
Ali
Old Dec 4, 2006 | 01:11 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: reverse lights stoped working (PrinceAli132)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrinceAli132 &raquo;</TD></TR><TR><TD CLASS="quote">Check the fuses.
Ali</TD></TR></TABLE>
And then the switch on the transmission.
Old Dec 4, 2006 | 02:08 PM
00gs-r's Avatar
Default Re: reverse lights stoped working (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">
And then the switch on the transmission.</TD></TR></TABLE>
X2
Old Dec 4, 2006 | 02:10 PM
Code Blue's Avatar
Default Re: reverse lights stoped working (00gs-r)
check the fuse, and then the reverse light switch in the transmission, then check the wiring.
Old Dec 4, 2006 | 09:26 PM
1uncleanDA's Avatar
Default Re: reverse lights stoped working (Code Blue)
I have the same problem where is the switch on the transmission?
Old Dec 5, 2006 | 04:38 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: reverse lights stoped working (1uncleanDA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1uncleanDA &raquo;</TD></TR><TR><TD CLASS="quote">I have the same problem where is the switch on the transmission?</TD></TR></TABLE>
It is part 10 in the diagram. Disconnect the plug and check for continuity both in and out of reverse.
Old Dec 5, 2006 | 08:31 AM
1uncleanDA's Avatar
thank you dogginator
Old Dec 5, 2006 | 08:33 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
My bro had a bad switch on his del Sol, he just ordered a new switch.
Old Dec 5, 2006 | 11:28 AM
NAmodified's Avatar
hell yeah dude! i was just moving that dam wire around and my dam **** works now. That was weird... Anyways thanks for the help!
Old Dec 5, 2006 | 11:34 AM
Community Builder
That probably means there is a loose or broken wire, which means it will probably stop working again in the near future.
folta2169
Aug 17, 2007 02:35 PM
MugenManR
Jan 5, 2007 08:53 AM
Special-K-Coupe
May 20, 2005 10:03 PM
1 point 6
Mar 10, 2005 11:52 AM
prelude_2k1
Jul 14, 2004 08:32 AM
