Resurfacing a flywheel?!
Old Feb 12, 2009 | 05:35 AM
scspeed's Avatar
Default Resurfacing a flywheel?!
I know you should always resurface when putting a new clutch in, my flywheel doesnt look to bad, I just bought a competition stage 5 four puck clutch with PP and am wondering if i can get away with out resurfacing...Like i said the flywheel doesnt look horrible, If i dont how bad with this hurn the clutch??
Old Feb 12, 2009 | 06:00 AM
PROJECT 91's Avatar
Default Re: Resurfacing a flywheel?!
sure you can. just dont do no launches or burnouts. break in the clutch and you should be fine.
Old Feb 12, 2009 | 08:23 AM
scspeed's Avatar
Ok, but the clutch was already broken in by sombody else...i was told it had roughly 500 miles on it..so either way...just drive it easy till teh clutch can meet the patern of the flywheel?
Old Feb 12, 2009 | 08:24 AM
sp00ledbseries's Avatar
ya give it around 150-200 miles to feel out the fly wheel. and dont do much highway driving
Old Feb 12, 2009 | 08:30 AM
scspeed's Avatar
Ok cool, so as long as i do this i should realy have no issue waht soever?
Old Feb 12, 2009 | 09:06 AM
I never have is the fly wheel in pretty good shape it aint rusted or anything is it
Old Feb 12, 2009 | 09:46 AM
ALLxMOTOR EG's Avatar
Vietnamese!
yep
Old Feb 12, 2009 | 05:46 PM
scspeed's Avatar
I cleaned the surface up with steel wool, the rest is kind of rusted but tht should be fine right??
Old Feb 12, 2009 | 06:16 PM
racebum's Avatar
we can't see your flywheel but if it's flat, smooth and you can't feel any warpage it should mate to your new clutch pretty well. i normally use an air sander with 180 paper if i'm reusing a brake rotor of flywheel. you just want to pull the glaze off, nothing more.
Old Feb 12, 2009 | 06:36 PM
scspeed's Avatar
ok thanks buddy,ill see if i can get a pick for you guys later...also anyone know where i can find an itr flywheel??
Old Feb 13, 2009 | 12:20 AM
racebum's Avatar
probably hmotorsonline or jdmenginescorp
however, the fidanza 7.5lb aluminum wheels are only $129 on ebay. they act like **** during break in but chill right down after 500 miles. i have one bolted to my ITR engine and it works like a charm.
Old Feb 13, 2009 | 03:14 AM
'00_GSR/R's Avatar
What's it like having that light weight flywheel on the ITR motor compared to the stock ITR flywheel?
Old Feb 13, 2009 | 08:29 AM
scspeed's Avatar
I dont like light weight flywheels. Specially for the way i use my car, i like the momentum of the weight of the flywheel to keep me going. Its all on the way you race your car. Thats why im kinda leaning more towards an itr. I used to have one, there nice cuz there not as light as aftermarket but yet not as heavy as the gsr or ls.
Old Feb 13, 2009 | 11:08 PM
'00_GSR/R's Avatar
Thats a good point.
Old Feb 14, 2009 | 01:27 AM
DC206R's Avatar
well i know everybody has the fidanza 7.5 one. but what about the exedy 9 lb or 11 lb flywheel. is that a little better for DD?
Old Feb 14, 2009 | 02:11 AM
racebum's Avatar
the exedy is the one i wish i would have bought. the fidanza is almost too light
Old Feb 14, 2009 | 03:05 PM
'00_GSR/R's Avatar
How much does the stock ITR flywheel weigh?
Old Feb 14, 2009 | 04:11 PM
racebum's Avatar
12
Old Feb 15, 2009 | 10:35 AM
scspeed's Avatar
So back on topic...the majority people on this post say, NO to resurfacing... And that i should be fine, as long as i take it easy for the 1st 500 miles correct??
Old Feb 15, 2009 | 11:16 AM
lsneo's Avatar
i would resurface just to be safe. I don't know how much resurfacing costs but it cant be that much. It sure as hell is better to spend the extra money than having to take everything out again just to do what you should have originally done.
Old Feb 15, 2009 | 11:46 AM
teg_duty_08's Avatar
The local Machine Shop was going to resurface my flywheel (98LS) for $40 but I could get a brand new one for like $80 from them so thats what I did instead. Works like a charm. Dman, Stage 5 is pretty intense, what kind of setup do you have? That almost seems like too much clutch for a DD car. just IMO though, so dont take it the wrong way.
Old Feb 15, 2009 | 06:29 PM
'00_GSR/R's Avatar
I drove a few stage 5's and I would never DD one. The clutch is either in or out, no in between.
To the OP, I would just get it resurfaced. It is such a small thing to cut corners on, and if something does go wrong its not going to be good. Many places can do it for you. I know les schwab does it. Some other tire places do too, and of course there are your local machine shops.
Old Feb 18, 2009 | 08:17 AM
scspeed's Avatar
Yeh i found out that its only costs 40 dollors to resurface at a shop locally.. Like you guys said, im just going ot do it to be safe..Whats 40 more dollors vs. messing something serious up in the long run. Also my car IS a daily driver, however it have nearly 450whp and i need a tough clutch, not to mention i track the car on weekends...I have driven a stage 5 comp b4 this one, it wasnt that bad. My friend has the same setup with the same clutch/pp etc. and he has no problem with using it as a dd....
Thanks for all your inputs guys!
Old Feb 18, 2009 | 08:40 AM
mouab18c1's Avatar
40 dollars to resurface a flywheel? wow i got mine done for 12 at NAPA
Old Feb 18, 2009 | 09:38 AM
94 TuRbO dC2's Avatar
Banned
ouch...
(mental note)
