Resetting ECU
Old Sep 9, 2003 | 03:56 PM
philibuster's Avatar
Default Resetting ECU
Alright, so I ordered my intake and I know I have to reset my ECU so it can adapt it. Question is, if I disengage the negative battery connection, will my alarm just go off??
Old Sep 9, 2003 | 03:58 PM
threatcon13's Avatar
New User
Default Re: Resetting ECU (SilverBlur01)
no your alarm wont go off. just disconnect it for 10 minutes and reconnect.
Old Sep 9, 2003 | 04:07 PM
VTECorona's Avatar
Default Re: Resetting ECU (Threatcon13)
Then start it and let it idle for about 5 or so minutes.
Old Sep 9, 2003 | 04:25 PM
MightyMouseTech's Avatar
You don't have to disconnect the battery. Just pull the radio/backup (the backup stands for ECU backup) fuse in the underhood fusebox for 10 seconds while the engine is off. You will have to reset your radio after this though.
Old Sep 9, 2003 | 05:08 PM
WOTTEG's Avatar
Default Re: Resetting ECU (MightyMouseTech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MightyMouseTech &raquo;</TD></TR><TR><TD CLASS="quote">You don't have to disconnect the battery. Just pull the radio/backup (the backup stands for ECU backup) fuse in the underhood fusebox for 10 seconds while the engine is off.</TD></TR></TABLE>
My thoughts exactly!
Old Sep 9, 2003 | 05:57 PM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Default Re: Resetting ECU (WOTTEG)
Agreed, pull the fuse. And if I pull my battery cable my alarm goes off when i try to reconnect it.
Old Sep 9, 2003 | 06:51 PM
xx dc2teg xx's Avatar
yeah same with me-- first time i did that scared the **** outta me... wait every time I do it --it still makes me jump
Old Sep 9, 2003 | 11:17 PM
es four's Avatar
From: You can be my wingman anytime...., Las Vegas, US
Default Re: Resetting ECU (VTECorona)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECorona &raquo;</TD></TR><TR><TD CLASS="quote">Then start it and let it idle for about 5 or so minutes.</TD></TR></TABLE>
Let the engine warm up to normal operating temp, then go out and beat on it, then shut it off.
EFstyle
Oct 5, 2007 10:21 PM
Pearlude
Nov 14, 2004 06:41 PM
bigslimdog
Audio / Security / Video
Mar 31, 2004 06:49 PM
bigslimdog
Mar 30, 2004 03:07 PM
RedHatch
Jan 2, 2002 08:34 PM
