replacing radiator core support...?
Old Nov 10, 2002 | 05:49 PM
gritsak's Avatar
Default replacing radiator core support...?
ive got a 95 2door gsr that needs a new radiator core support..from the looks of it, it doesnt bolt on/off....so im assuming that it has to be cut out and a new one welded in place? anyone know one way or the other how to replace the support? and also, if anyone has had it done at a body shop, do you have an approximate cost? TIA
Old Nov 10, 2002 | 06:30 PM
Solipsist's Avatar
Default Re: replacing radiator core support...? (gritsak)
Yes, its welded on by three points. My labor guide gives it about 90.00 for the upper core support with 2 hrs labor time. about $225.00 Remember,this time is after bumper and all necessary bolted on parts are removed.
If you are needing the whole core support assembly done, your looking at 950.00 with parts & labor. Time includes R&I/R&R of the radiator, fan shroud, both headlamps, hood lock, support rod, coolant expansion tank, horn, power steering cooler, washer reservoir, AC condenser & lines, dehydrator and D&R of hood release cable and wiring as necessary.
Good luck
http://www.memorialauto.com
Old Nov 10, 2002 | 06:48 PM
gritsak's Avatar
Default Re: replacing radiator core support...? (TEXASLS95)
thanx for the reply...most the stuff is already and out (and smashed up, due to the accident) but the remainder ill pull out myself and just have the body shop weld the new support in, and hopefully be a fairly "easy" fix from there on...thanx again
Silentz
Jun 8, 2018 05:56 AM
1996hondaaccord
Aug 11, 2008 03:11 PM
SIRIUS VTEC
Jun 8, 2008 12:14 PM
HybridHatchback
29
Jul 30, 2003 11:17 AM
