Replacing battery cables...
I have a brand new battery in my Integra and so I assumed it wasnt the problem. I checked it out and there is no corrosion on the battery or terminals, but all the way down the inside of the wire there is corrosion. Any tips on removing and replacing the cable and preventing this from happening again? Ground problem maybe?
it would help if we knew WHAT your problem was in the first place.
and yes, replacing wires isnt a bad idea, i dont know what you mean by tips... wire are wires.
at least clean off the corosion.
are you serious? i said exactly what the problem was.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ERIC! »</TD></TR><TR><TD CLASS="quote">I checked it out and there is no corrosion on the battery or terminals, but all the way down the inside of the wire there is corrosion.</TD></TR></TABLE>
There is corrosion throughout the INSIDE of the WIRE.
Tips = Advice
Maybe an idea of how I could prevent it from getting corrosion again.
Thanks for nothing idiot.
Tips = Advice
anyone else with some help would be great. im going to replace all the cables, but i want to know how i can prevent the corrosion from happening again.
SMcCoyEX
Honda Civic (2001 - 2005)
Mar 4, 2016 07:30 PM
