replacing ABS o-ring under accumulator
Old Aug 8, 2008 | 04:09 AM
-DC2-'s Avatar
Default replacing ABS o-ring under accumulator
so, i found this old thread:
https://honda-tech.com/zerothread?id=1451186
my question: given that the accumulator is full of compressed nitrogen, when i remove the accumulator from the motor assembly, does the accumulator need to be recharged? or, is the accumulator sealed and all that is released when you remove it is compressed brake fluid?
Old Mar 27, 2015 | 03:33 AM
stallion15's Avatar
Default Re: replacing ABS o-ring under accumulator
I actually did this TODAY to replace the accumulator o-ring if you can believe it on an Integra that is 20 years old. It's compressed brake fluid that shoots out from the bottom when you remove the two 10mm accumulator bolts from the underside of the accumulator. DO NOT REMOVE THE BOLT ON THE TOP OF THE ACCUMULATOR THAT HAS THE EPOXY SEAL ON IT OR YOU WILL BE SORRY.....
clemsoncb7
Jan 22, 2010 02:09 PM
JDMeman
Dec 26, 2007 12:21 PM
GraphiteMW
Jan 30, 2007 12:25 PM
msinsky14
Nov 29, 2006 08:44 PM
Drew M
Dec 29, 2002 07:47 PM
