Removing bolt from cat...?
Old Feb 13, 2003 | 06:39 AM
RuskeR's Avatar
Default Removing bolt from cat...?
When I installed my comptech exhaust last week I ended up stripping one of the three bolts coming from the cat. I took of the cats heatshield to see if I could remove the bolt and replace it. I don't think it's wleded on there at all but, it wouldn't come off even after a few wacks with a hammer. Anyway, should I just have a shop cut off the bolt and replace it with a new one? I'm afraid in awhile I'll end up with an exhaust leak. I think that's way the exhaust has been pinging so bad.
Any other ideas? Thanks
Old Feb 13, 2003 | 07:25 AM
Mr.Rab's Avatar
Default Re: Removing bolt from cat...? (RuskeR)
Hey RuskeR:
I think this is what you are talking about.
If your stud looks anything like this, I'd say just keep torquing that bolt on, until you get a tight enough seal. this is what I had to do and had no problems afterwards.
[Modified by Dr.Rab01gsr, 10:02 AM 2/13/2003]
Old Feb 13, 2003 | 07:37 AM
OneSloTeg's Avatar
Default Re: Removing bolt from cat...? (Dr.Rab01gsr)
Old Feb 13, 2003 | 08:18 AM
PolySquared's Avatar
Default Re: Removing bolt from cat...? (OneSloTeg)
willing to sell your stock cat? oops nm, i thought you installed a new cat.
[Modified by PolySquared, 5:19 PM 2/13/2003]
Old Feb 15, 2003 | 09:38 AM
RuskeR's Avatar
Yeah mine looks the excat same way. Can that bolt be taken out and replaced? I've hit it a few times with a hammer but, it doesn't move at all. Guess I need a shop to do it?
Old Feb 15, 2003 | 09:43 AM
au-gsr's Avatar
you really have to give that bolt a good whack it has a gnurled head that grips intothe meatla of th ecat plate it bolts up to. and any bolt will work to replace it so don't go out and bu a honda bolt for five buck. even if it is standard it will work. i had the similar problem but mine was the bolts were rusted to the cat so i had to dremel the rust off the lip so i could get those bolts off(renedering the locking bolts useless) so i just wentto the hardware store bought 1 1/2" bolts two washers and two nuts. fixed it and they are new so when you need to work on em later they'll come off easier.
Old Feb 15, 2003 | 10:41 AM
Aaron M's Avatar
Default Re: Removing bolt from cat...? (au-gsr)
PB Blaster plus a 2 foot long pipe over the wrench did it for me
Old Feb 15, 2003 | 12:28 PM
Hairy Gorilla's Avatar
Default Re: Removing bolt from cat...? (SilverB18C1)
I remember when I was doing my exhaust on my old car, first we took off the heat sheild around it to get the best access. Sprayed it with some sort of lube, and used the biggest cheater bar we could. We both pulled with all of our might and it came out pretty easy then.
Old Feb 15, 2003 | 12:43 PM
au-gsr's Avatar
Default Re: Removing bolt from cat...? (TimmyMaryak)
he doens't need to unbolt it he needs to remove the bolt, are you guys a lil deaf to what he was asking?
Old Feb 15, 2003 | 01:32 PM
Aaron M's Avatar
lol dude, are you asking to loose another 5%?
your comments help nobody
Old Feb 15, 2003 | 01:42 PM
Mr.Rab's Avatar
au-gsr doesn't know what he is talking about he just a big ol HT bully.
BTW where your avatar.
Old Feb 15, 2003 | 02:11 PM
Aaron M's Avatar
Old Feb 15, 2003 | 02:51 PM
au-gsr's Avatar
the mods took it away-i went awall last night because threatcon as on the board and he pissed me off last time. but i'll have to come up with a new avatar as soon as i converse with one of the mods about letting me do so.
Old Feb 15, 2003 | 04:15 PM
Mr.Rab's Avatar
THE MODERATORS, hahaha.
The power they have in this forum, is almost like a dicatorship.
Old Feb 15, 2003 | 04:16 PM
au-gsr's Avatar
i feel like am posting in a communist nation or something. j/k!!
Old Feb 15, 2003 | 10:30 PM
RuskeR's Avatar
Yeah the problem is the bolt is stripped. So I cannot put a nut on unless I replace the bolt. So, just keep whacking it with a hammer? haha
Kyles ej1
Oct 6, 2005 11:54 AM
H0ndaJunkie
Jul 12, 2005 12:45 PM
LAKER HATER
Aug 8, 2004 11:00 AM
svw
Sep 25, 2003 09:33 PM
98cwitr
Dec 8, 2002 07:51 PM
