removing abs on a DA
Old Oct 11, 2007 | 08:14 AM
jdmjunkie8's Avatar
Default removing abs on a DA
I got my skunk2 front strut bar yesterday and you have to remove abs to fit it in. I was wonderin is there anything I have to be careful around so I dont mess somethin up?
Old Oct 11, 2007 | 10:44 AM
super jdm yo's Avatar
Default Re: removing abs on a DA (jdmjunkie8)
i thought that the skunk 2 bar fits with abs? is it the one that looks like a spoon bar? well i must be mistaken then. but is it really worth it to get rid of your whole abs for a strut bar? unless your don't want it or it doesn't work. i really don't know jack about abs except for my car has it. so good luck and if no one here answers your question i would check g2ic.com
Old Oct 11, 2007 | 09:47 PM
jdmjunkie8's Avatar
Default Re: removing abs on a DA (super jdm yo)
Havent tried it yet but it doenst look like it would fit, I also just want it removed to make the engine bay a little cleaner also. Thanks for the reply though, hopefully I can find a answer before I just go at it.
Old Oct 11, 2007 | 10:25 PM
SIC_jdm_da9's Avatar
just go to the junk yard and grab a 1990 non abs thing and use that... i got a 1990 RS with no ABS
Old Oct 12, 2007 | 05:58 AM
ziggy7's Avatar
From the searching I did after my Accelerator pump went out on my old car, It's a fairly large undertaking. It's not just removing the resivour and no longer having abs. You need to get the system out of a non-abs car and change the master cylinder, the brake lines and possibly the calipers as well.
If your abs is non functional go for it, otherwise I'm not sure it's worth it just to put a strut bar in when you can find strut bars that will work with it still in the car.
Old Oct 12, 2007 | 08:30 AM
DC209's Avatar
thats gana be alot of work for a strut bar
Old Oct 12, 2007 | 09:17 AM
jdmjunkie8's Avatar
Default Re: removing abs on a DA (ziggy7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ziggy7 &raquo;</TD></TR><TR><TD CLASS="quote">From the searching I did after my Accelerator pump went out on my old car, It's a fairly large undertaking. It's not just removing the resivour and no longer having abs. You need to get the system out of a non-abs car and change the master cylinder, the brake lines and possibly the calipers as well.
If your abs is non functional go for it, otherwise I'm not sure it's worth it just to put a strut bar in when you can find strut bars that will work with it still in the car.</TD></TR></TABLE>
Thanks dude, i got some thinking to do. Maybe in the long run when I pull the motor would probably be a easier time to do it.
Old Oct 12, 2007 | 01:51 PM
ziggy7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmjunkie8 &raquo;</TD></TR><TR><TD CLASS="quote">
Thanks dude, i got some thinking to do. Maybe in the long run when I pull the motor would probably be a easier time to do it.</TD></TR></TABLE>
Bingo!!! Brake lines are much much easier with no motor in the way!
lesagueneen
Honda Fit
Jul 22, 2018 10:11 AM
1991 Teggy
May 20, 2008 12:53 PM
donnsterr
Jan 23, 2008 02:00 PM
turboda4dr
May 3, 2007 11:23 PM
jdm_SirG
Jan 21, 2006 09:12 PM
