removing abs
Old Dec 5, 2006 | 03:14 PM
turbob18si's Avatar
Default removing abs
what exactly is needed to remove the abs system?
Old Dec 5, 2006 | 03:19 PM
PrinceAli132's Avatar
Default Re: removing abs (turbob18si)
https://honda-tech.com/zerothread?id=1160671
Ali
Old Dec 5, 2006 | 03:20 PM
KBG Indey's Avatar
2 options, since im doing this right now
1. rs prop valve, full stainless steel lines from brake master cyl to rs prop valve, then you can use rs hardlines to the wheel wells, or stainless lines all the way to the brakes.
or
2. rs brake booster, rs master cyl, rs prop valve, rs hardlines and there you go
Old Dec 5, 2006 | 03:40 PM
turbob18si's Avatar
Default Re: (IndeyAttack)
thanks for the help guys
mmcsiggi
Suspension & Brakes
Nov 2, 2010 12:20 PM
dc4teg95
Feb 23, 2009 04:15 AM
cxhatch93
Oct 22, 2008 06:56 PM
VTEC_PRODUCTION
Dec 5, 2007 09:42 AM
k624ash
Aug 31, 2006 09:31 AM
