Removed dash having problems help.
Well I bought a 97 4 door gsr with a cut dash harness, so i took the dash out my car today so i can take out the hacked up harness. The problem i am having is, I cant take the dam climate control off, What is needed to remove the climate control. Need help.
there is a black coated wire underneath the passenger side of the dash that attaches to a little white thing (i don;t know how to describe it) It runs from the center console....the heat control pulls it.
If you cant find it, have a friend move the temp. lever back and forth and you should see it moving.
just got done replacing the complete lower dash harness on a 95 gsr. It was a pain the ***. The air mix control cable is a bitch gettin back in to control unit.
Zoso1977
Nov 6, 2004 10:57 PM
