rebuilding head , what else to do
Old Jan 5, 2004 | 09:00 AM
JBBNJ609's Avatar
Default rebuilding head , what else to do
ok some im gonna get the head rebuilt for the hell of it and the car has already been down for like 3 months cuse of an accident , and everything else is getting redone , new tranny , flywheel , paintjob new front end , new lights with hids, and now i found otu i have enough to do a head rebuild , so im gonna take that off what else so i do , i dont have much xtra money , but im thinking new headgasket , new oil pump ring gear ( a new billet one so i can do high rpms and not have to worry) what else you guys ?? and also show me some better then stock intake manifold gaskets , better then stock headgasket , and better then stock timing belt please thanks
JAY
Old Jan 5, 2004 | 11:27 AM
IMPATIENT's Avatar
Default Re: rebuilding head , what else to do (jason bouchard)
im assuming you have an integra so, are you rebuilding your head back with stock valvetrain components or are you going to actually BUILD the head?, if your planning to do a stock rebuild new valve seals are a definite and valve springs, retainers and valves can usually jsut be cleaned and put back together with no problems unless of course there damaged before hand, if your gonna build the head for any application whether it be FI or all motor there are lots of aftermarket companies that sell, valvesprings, retainers, valves,cams etc....just do your research on what you think would fit your application best, head gaskets depend on your purpose, if your boosting and want to run more boost on stock internals get a thicker one, if your running all motor i think spoon sells a thinner gasket to raise compression, cometic sells a good gasket for turbo applications if you want to keep your compression the same, and of course stock gaskets are, well....stock, and theyll serve there purpose just as well as any other gasket without raising compression.....
intake manifold gaskets-stock of course that will be just as good for a stock rebuild or, HONDATA HEATSHIELD GASKET is tite, its 68 bucks and will drop your intake manifold temps dramatically, i have it on my car and its very nice, i can drive around in my car for hours, come back and put my hand on the manifold and not worry about it being to hot that it will burn me, i mean its hot but not scalding hot like with stock gaskets.......and i gained 10 hp from that gasket.......
i personally wouldnt recomend anything but a stock timing belt but there are companies that sell them, i thought spoon also sold one and for some reason i thought skunk2 did as well but im not certain.....just post back on what you plan the car to do and how much power your trying to make or if your just building it back to stock and im sure other users can give some info.......
Old Jan 5, 2004 | 11:06 PM
JBBNJ609's Avatar
Default Re: rebuilding head , what else to do (IMPATIENT)
ok im gonna go turbo , but not for a long while like a year or more , im not sure what stuff im gonna rebuild it with oem/ aftermarket , i have to talk to the builder . . i wanna go aftermarket but im not the one paying for it , and i have to go with the builder wants to use for parts ( then i get a warenty from him i fi use the parts he likes) . . .
Old Jan 7, 2004 | 08:39 AM
JBBNJ609's Avatar
up
092eg6
Aug 7, 2009 04:50 AM
AlienKrOZ
Dec 23, 2006 11:13 AM
b18sihatch
Jul 12, 2006 11:04 AM
caspers_hatch
Jun 6, 2005 02:09 AM
Curtis2kul
Jun 21, 2004 04:59 AM
