rattling
Old Jan 15, 2008 | 08:51 PM
yella-dragon's Avatar
Default rattling
3000-3500 rpm it makes really weird noise like a rattling only on thoes rpm in any gear?
*help a noob*
Old Jan 15, 2008 | 09:48 PM
SWE3TDUDE's Avatar
Default Re: rattling (yella-dragon)
Damn man, I thought it was just me but I have seen a lot of threads lately on about this rattle. I have a 96 GSR that does the exact same thing between those RPM and ONLY between those RPM. Let me know if you ever figure it out, I might just take it to Acura and have them do it because its beggining to get on my nerves! *subscribed*
Old Jan 15, 2008 | 10:18 PM
my4drGSR909's Avatar
Default Re: rattling (SWE3TDUDE)
omg ive seen the same thing over and over. its called butterfly vavle. search it read it and learn it. search gsr butterfly valve
Old Jan 15, 2008 | 10:35 PM
TehGhett0P1mp's Avatar
Default Re: rattling (my4drGSR909)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by my4drGSR909 &raquo;</TD></TR><TR><TD CLASS="quote">omg ive seen the same thing over and over. its called butterfly vavle. search it read it and learn it. search gsr butterfly valve </TD></TR></TABLE>
Im not sure what your smoking but I dont think that has anything to do with it..if you guys still have the OEM headers. Im willing to bet money it has to do with the heatshield thats on that header or at least something with the header itself. I used to have the same noise only around those rpms and I got a new header not because of that but because of a different reason and the noise is gone.
You COULD just take the heat shield off but iron gets real hot real quick and its so close to your hood. Dont wanna think what could happen.
Old Jan 15, 2008 | 11:05 PM
clean3two3's Avatar
Default Re: rattling (TehGhett0P1mp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TehGhett0P1mp &raquo;</TD></TR><TR><TD CLASS="quote">
You COULD just take the heat shield off but iron gets real hot real quick and its so close to your hood. Dont wanna think what could happen.</TD></TR></TABLE>
x2 or exhaust may rattle
Old Jan 16, 2008 | 12:21 AM
IamPhil's Avatar
Default Re: rattling (clean3two3)
mine is the heatshield right under the shifter.. but I went around my car with a wrench and just tapped everything to see what's loose and once you hit the right heatshield it gets really obvious!
Modified by IamPhil at 2:07 AM 1/16/2008
Old Jan 16, 2008 | 05:08 AM
jhammond_82's Avatar
Reject Papi
Default Re: rattling (IamPhil)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IamPhil &raquo;</TD></TR><TR><TD CLASS="quote">mine is the heatshield right under the shifter</TD></TR></TABLE> most educated response yet. butterfly valve? yeah, go ahead and search that, nothing comes up.
Old Jan 16, 2008 | 05:12 AM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: rattling (jhammond_82)
hahaha butterfly valve OMG like NO WAY
Old Jan 16, 2008 | 05:25 AM
integra4eva's Avatar
Default Re: rattling (GRAF-FITI)
well if its the heat shield then i think it would of ratled the day you got the car, id say its the exhaust... as strange as it may sound i had the problem only for about a week, thats when i figured out that i actualy melted one of the honey comb peices in my catalytic... and suprisingly no check engine light..
Old Jan 16, 2008 | 06:28 AM
Reject Papi
Default Re: rattling (integra4eva)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra4eva &raquo;</TD></TR><TR><TD CLASS="quote">well if its the heat shield then i think it would of ratled the day you got the car</TD></TR></TABLE> not necessarily, the bolts could have worked there way loose due to driving conditions ie; bumpy highways ect. just because it wasn't rattling a month ago doesn't mean that it wont. thats like saying if it was a rod knock, it would have done it when you got the car. things do just happen you know.
Old Jan 16, 2008 | 08:59 AM
da_33's Avatar
Its not the heat shield around your headers, its the heat shield past your cat converter. Remove it or bend it a different way
Old Jan 16, 2008 | 12:27 PM
Dogginator's Avatar
Daisy... Daisy...
Check the exhaust for rattles. Either have a friend rev the car to make the noise or lightly tap on the exhaust with a hammer to find the rattle.
Old Jan 16, 2008 | 07:08 PM
blackcherry's Avatar
mine does it at the same rpm especially on the highway, but it sounds like its definately coming from the rear. . .possibly the heat shield under the shifter, i have yet to remove it and see but it is quite annoying
Old Jan 16, 2008 | 07:23 PM
Default Re: (da_33)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by da_33 &raquo;</TD></TR><TR><TD CLASS="quote">Its not the heat shield around your headers, its the heat shield past your cat converter. Remove it or bend it a different way</TD></TR></TABLE>
On mine the bolts were loose causing the one on the headers to raddle, but it does have something to do with your exhaust system. If you can get it on a lift or some stands I would get under and start tapping things with a mallet or hammer to see if something doesn't sound right.
From what I have read raddles from the exhaust is pretty common on tegs for some reason..
Old Jan 16, 2008 | 09:41 PM
db1_jdm's Avatar
This guy is complete idiot.
Old Jan 16, 2008 | 09:45 PM
db1_jdm's Avatar
Default Re: rattling (db1_jdm)
hahahah i had to make it my signature!! lmao<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by my4drGSR909 &raquo;</TD></TR><TR><TD CLASS="quote">omg ive seen the same thing over and over. its called butterfly vavle. search it read it and learn it. search gsr butterfly valve </TD></TR></TABLE>
Old Jan 16, 2008 | 09:49 PM
Mfoehrkolb's Avatar
I have a rattle also, and what it is. Is the header. sounsd like its commign from theback but its actually the front. Where the header combines on mine it is held on by 4 bolts in each corner, and the 1 corner keeps losening and it rattles like a mother fvcker. ***** so annoying and im too lazy to keep tightening it. ima just wait til i get the turbo manifold.
Old Jan 17, 2008 | 04:57 AM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by db1_jdm &raquo;</TD></TR><TR><TD CLASS="quote">hahahah i had to make it my signature!! lmao</TD></TR></TABLE>
Although in this case the quote you mentioned is indeed idiotic, most GSRs (DC2 and DB8) have butterfly valves. Why would you put that in your signature?
Old Jan 17, 2008 | 05:05 AM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: rattling (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">
Although in this case the quote you mentioned is indeed idiotic, most GSRs (DC2 and DB8) have butterfly valves. Why would you put that in your signature?</TD></TR></TABLE>
hahaha
Old Jan 17, 2008 | 02:36 PM
WookinPaNub's Avatar
Pwnd
Old Jan 17, 2008 | 09:40 PM
i have on dc headers and my mechanic said its the heatshild under the headers but im to damn lazy and its cold out to bend it back
Old Jan 18, 2008 | 05:15 AM
GRAF-FITI's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yella-dragon &raquo;</TD></TR><TR><TD CLASS="quote">i have on dc headers and my mechanic said its the heatshild under the headers but im to damn lazy and its cold out to bend it back </TD></TR></TABLE>
if you are too damn lazy then why even bother asking for help?
Old Jan 18, 2008 | 06:03 AM
Reject Papi
you have headers!? and heatshilds!?
Old Jan 18, 2008 | 07:17 AM
jomama's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRAF-FITI &raquo;</TD></TR><TR><TD CLASS="quote">
if you are too damn lazy then why even bother asking for help?</TD></TR></TABLE>
seriously. however, i don't envy your living in calgary of all places. check your header/exhaust/cat shields when it gets into positive degree territory.
Old Jan 18, 2008 | 08:55 AM
kon's Avatar
kon
Default Re: rattling (vtechreppin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtechreppin &raquo;</TD></TR><TR><TD CLASS="quote">
3000 is when vtech hits. no big deal</TD></TR></TABLE>
hahahha
