rack and pinion
Old Oct 7, 2003 | 11:19 PM
NuclearB18B's Avatar
Default rack and pinion
how do you know if it's going out?
Old Oct 7, 2003 | 11:24 PM
Downey's Avatar
Default Re: rack and pinion (ha illuminato un)
you have powers steering i assume. check you belt. make sure its tight. does it make any noise? check under the car or look being the intake manifold and check from leaks in the boots. does the steering feel heavy? check your tires pressure. lots of things that might make it feel wierd. does it have slop in it, by that i mean, by turning the steering wheel will the wheels move right away?
Old Oct 7, 2003 | 11:43 PM
Default Re: rack and pinion (Downey)
well, i've got this clunking sound sometimes. sounds kinda like something is popping back into place.
Old Oct 8, 2003 | 05:21 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ha illuminato un &raquo;</TD></TR><TR><TD CLASS="quote">well, i've got this clunking sound sometimes. sounds kinda like something is popping back into place.</TD></TR></TABLE>Sounds more like ball joints. They're not too hard to check out. Don't forget the outboard & inboard ones on the steering rack...
vinuneuro
Suspension & Brakes
Nov 21, 2010 11:28 PM
GsDAteg
Mar 15, 2006 12:20 PM
RiCE On IcE 2
Dec 17, 2003 05:17 PM
RedRacerCivic
Sep 12, 2003 05:56 AM
sacredc0w69
Aug 26, 2003 11:07 AM
