Question on HIDs
Guest
Posts: n/a
I am about to buy an HID kit from Mculloch...........i wanted to know if this is a good brand or not from those whohave run these in the past. Also, I can use these to do the HID retrofit with HID projectors, right ? I read somewhere that you have to convert the bulb housing to fit 9005, but thats not so for the plug and play kits, correct ?
these will be a problem when you want to do a HID retro. The "kit" uses 9006 bulbs, but HID projectors will use D2S, so you will need to either buy new ballasts or custom splice a D2S plug adapter to fit. If you're even thinking about doing a retro, think more about saving up for the retro now so you don't have to get rid of your 9006 kit.
If u plannin on doing a retro just get everythin oem...meaning get the oem ballasts, bulbs, and projectors...mccullogh(sp) kit are a waste of money now...save your money and do it right the first time...
