question about rpm's
Old Apr 16, 2003 | 09:25 AM
dip-set's Avatar
Default question about rpm's
ok now i know the rpms will sit at about 1000 when moving and car is in nuetral till u come to a complete stop then they will drop to idle...my question is lately my rpm's will sit at about 1500 to 2000 rolling in nuetral and then when i come to a complete stop it takes a minute for them to drop to idle...or when im shifting from first to second at low rpm (2500 to 3500)sometimes the car will jerk forward a lil as if im giving it gas between shifts but its do to the rpms not dropping down fast enough....any insight as to why my 96 ls is doing this now...only thing ive done to the car was change the radiator yesterday and i noticed it starting to do this when i realized i had a small crack in the rad...but after replacing the rad. it still is doing it...car had a full tune up about 4000 miles ago,so i doubt its the plugs ,wires,cap or rotor...also i reset the ecu today on my luch break to see if it helps...thanks for all and any advice given....
Old Apr 16, 2003 | 09:39 AM
neo1z's Avatar
Default Re: question about rpm's (teg-your-it)
It sounds more like a throttle issue...You havent been chillin around your intake manifold or throttle body lately, have you?
Old Apr 16, 2003 | 09:43 AM
dip-set's Avatar
Default Re: question about rpm's (neo1z)
no but i did notice my throttle pulley was dirty on the spring looking part...maybe its getting dirty/sticky?
Old Apr 16, 2003 | 10:14 AM
dip-set's Avatar
ttt....and stay there... any other ideas please? what would be a good cleaner to use on the throttle pulley...after that i"ll wd40 it...anything else it might be?
Old Apr 16, 2003 | 10:45 AM
dip-set's Avatar
some one any one have the slightest idea...it cant be anything major...worst comes to worst i"ll clean the throttle pulley tonight lube it up and see what happens and i'll let ya know tomorrow...
Old Apr 16, 2003 | 11:32 AM
dip-set's Avatar
can i use brake cleaner to clean the throttle pulley?
Old Apr 16, 2003 | 11:59 AM
dip-set's Avatar
up up and away
Old Apr 16, 2003 | 12:12 PM
Scary1109's Avatar
stop TTT'ing this question, and it's rpm not rpm's. posting this to the top every half hour just makes people not want to help you. and no don't use brake cleaner.
Old Apr 16, 2003 | 12:14 PM
dip-set's Avatar
Default Re: question about rpm's (Scary1109)
what should i use then guy..
Old Apr 16, 2003 | 12:23 PM
dip-set's Avatar
ok mods please delete this thread...its obvious i wont get any insight on my "lil" problem...thank you
Eledarmi
Mar 30, 2017 02:20 PM
dices543
Jul 24, 2010 09:16 PM
kekekekevin
Jul 24, 2006 12:17 AM
94teg_ucb
May 9, 2003 06:48 AM
