Question about an Integra dash
Old Mar 20, 2003 | 08:04 PM
civicmandx94's Avatar
Default Question about an Integra dash
First of all I don't know if this is the right forum or not so I figured I would start here. What I want to do is swap an integra dash into an 5th gen civic coupe. I want to use every part of the dash console including the gauges and center consoles. Is this even possible? If it is what kind of modifications would have to be made to the dash to make it fit? Thanks for all you help in advance and God Bless!!
Old Mar 20, 2003 | 09:02 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: Question about an Integra dash (civicmandx94)
Sorry, I'm not being of much help, but I do want to clear up one of your questions.
YES, it is possible. My friend has it done on his hatch.
Old Mar 20, 2003 | 09:33 PM
xteg95's Avatar
wow...that seems like A LOT of work
Old Mar 21, 2003 | 07:04 AM
Default Re: Question about an Integra dash (xintegra01)
I was fiberglassing a dash out of another civic. I fabricated another spot allmost identical to the where the gauges sit originally and molded it to the dash right above the heater controls, and I was going to put my tach and other gauges in there but it is looking a little ricey I think. I want something clean for my car for the interior and thought about switching out for an integra dash because I like the look of them. But what year integra do I need to make the swap a success. And will the gauges have the same wiring or will I need to wire it in somehow. Thanks for the help and God Bless!
Old Mar 21, 2003 | 08:19 AM
crazy eyez killa
Guest
Posts: n/a
My friend Liam has an ITR dash in a 95 hatch.
PM me and i'll get you his H-T screenname.
Edit: My PM don't work yet, damn newbie status.
[Modified by BrianDC2, 9:20 AM 3/21/2003]
Old Mar 21, 2003 | 07:02 PM
LS511's Avatar
Default Re: Question about an Integra dash (BrianDC2)
That's a cool idea but a lot of work. I'm sure it'll look great though. Post pics later
Old Mar 21, 2003 | 08:13 PM
bikeboy80's Avatar
Default Re: Question about an Integra dash (LS511)
i've done it in my hatch, it was a fair amount of work, and its definatly not just a bolt in afair, there is some hacking away at the underside of the dash below the gauge cluster, and some mounts to be made up for either side, the wire harness pluged right in for me but i also just used a whole integra main wire harness you will also need at least the heater box from a teg so youre vents match up. It will actually make it alot easier if you can find a donor car for the swap. Also neither the integra or the civic door panels will fit without modification. heres some pics
Old Mar 21, 2003 | 09:30 PM
OneSloTeg's Avatar
Default Re: Question about an Integra dash (bikeboy80)
Old Aug 12, 2004 | 04:41 PM
redvic's Avatar
Default Re: Question about an Integra dash (OneSloTeg)
OneSloTeg what did you use to mold you door panels and where car i get it?
Old Aug 12, 2004 | 04:44 PM
iixerOii's Avatar
Default Re: Question about an Integra dash (redvic)
Hope this thread helps.
https://honda-tech.com/zerothread?id=954173
Old Aug 12, 2004 | 04:55 PM
ernald711's Avatar
make sure that the VIN numbers match on the dash and the civic when/if you decide to do this...
Matt_2078
Oct 25, 2005 06:33 AM
ILOVEGIRLS
Mar 21, 2004 11:16 PM
civicmandx94
Mar 20, 2003 08:36 PM
