Question about door alignment..
Old Oct 18, 2003 | 09:35 AM
vtec.dc2's Avatar
Default Question about door alignment..
Comparing 2 sides of the car, one side seem to have door aligment where door is sticking out by little.. no leaks . car was like that when i bought it new (its not anything major - its doesn't aligh with rear quater panel perfectly, but as an owner - i can tell the difference)
My questions is, if i try to remove and to re-align it, will that make things worse? will it create leaks?
Old Oct 18, 2003 | 11:29 AM
silvernick711's Avatar
Default Re: Question about door alignment.. (vtec.dc2)
mines been in a accident and its off just a bit, but before mine was also. I asked soem guys at a body shop and they said to check all the door locks and brackets to make sure they were tight and sure enough mine was loose so it didnt engage the door all the way so it stuck out.
Old Oct 18, 2003 | 02:45 PM
es four's Avatar
From: You can be my wingman anytime...., Las Vegas, US
You mean, the door doesn't line up with the rear quarter panel right? Like it doesn't sit flush, as if the door is still open a little?
Its an easy fix. Open your door, and on the side of the car (where the door closes) You'll see the door latch. Its a silver latch with 2 screw on top / bottom of it. Loosen them up a bit and slide the latch back a tad. Tighten and see how it fits. Keep adjusting till door fits flush.
-Will
Old Oct 18, 2003 | 06:53 PM
vtec.dc2's Avatar
Default Re: Question about door alignment.. (integra707)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra707 &raquo;</TD></TR><TR><TD CLASS="quote">You mean, the door doesn't line up with the rear quarter panel right? Like it doesn't sit flush, as if the door is still open a little?
-Will</TD></TR></TABLE>
somewhate like that.. its not crooked, but it seems to push out towards the back where it sticks out further than rear quater panel.. and it sems to go deeper towards the mirro side..
as long as were're talking about the same thing.. i'll give it a try.. thanks
smilindave
Paint and Body
Feb 8, 2014 09:23 PM
mataliandy
Jul 12, 2010 06:24 PM
suhteevin
Jan 6, 2009 09:04 PM
ex voto
Nov 15, 2005 11:35 PM
tupark
13
Apr 25, 2004 03:27 AM
