Problems List on my 92 DA
Old Oct 17, 2006 | 05:50 PM
Rajin's Avatar
Default Problems List on my 92 DA
Ok, heater isn't working, thats on, checked the heater motor, was bad replaced, still no go. I think there is a short.
Interior light isn't working.
Clock is resetting itself after being cut off.
When trying to turn interior light on, the light for the rear defroster comes on then off then flickers then it stops.
Maybe you guys can help me find out what I missed.
Old Oct 17, 2006 | 08:21 PM
Rajin's Avatar
Default Re: Problems List on my 92 DA (Rajin)
Yeah. Wonderful help everyone.
Old Oct 17, 2006 | 11:11 PM
manyakiexpi's Avatar
looks like your electrical is all fucked up. unless your good at working on da electrical system u better just find somone to do it for u because it sounds like a bitch for what ur problem is for your car. good luck though
Old Oct 18, 2006 | 06:12 AM
Extreez's Avatar
Default Re: Problems List on my 92 DA (manyakiexpi)
atleast no motor problems put it this way, as for all does problems run a new wire for all light and whatevers giving u problem dont go REWIRING the hole car for this, just wire it ur self on the problems you have or maybe check ur fuses. let me know how it goes
Old Oct 18, 2006 | 09:50 AM
projectTeG's Avatar
replace the control unit behind the interior fuse box(i forgot the name of it). they unit control alot of those functions. as for the heater not working, is it not heating up of is fan not blowing? if its not heating up check the linkage and see if its connected on the heater valve in the engin bay on the upper heater hose.
Old Oct 18, 2006 | 10:22 PM
Rajin's Avatar
Default Re: (projectTeG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG &raquo;</TD></TR><TR><TD CLASS="quote">replace the control unit behind the interior fuse box(i forgot the name of it). they unit control alot of those functions. as for the heater not working, is it not heating up of is fan not blowing? if its not heating up check the linkage and see if its connected on the heater valve in the engin bay on the upper heater hose.</TD></TR></TABLE>
YOU.
Your my source. The fan kicks on when it feels like it.
Short Im think, I had to make a new ground for one of my headlights too.
I blame it on the guy who repaired the front end of the car.
Everything works until a big dumb **** who works at his office made some lame joke.
After then.
My ****'s not worked at all.
Old Oct 19, 2006 | 08:18 AM
projectTeG's Avatar
Default Re: (Rajin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rajin &raquo;</TD></TR><TR><TD CLASS="quote">YOU.
After then.
My ****'s not worked at all.</TD></TR></TABLE>
speaking of the grounds check the ground boxes in the front, they are clearish/yellow and have like 7 ground wires in them...there should be 2. i had one disconnected and i lost function of my horn, climate control, headlights...etc, everything was going haywire.
Old Oct 19, 2006 | 09:36 PM
Rajin's Avatar
Good call.
This DA was hit in the front because of bad calipers. That was the shittiest wreck ever.
I'll try that later today.
bigballer8526
Honda Fit
15
Aug 31, 2009 07:20 PM
topREV
Oct 20, 2006 09:59 PM
j_kevin_ca
Aug 9, 2006 08:02 AM
Que_Lude
Jan 19, 2003 03:36 PM
