power window problem help!!
Old May 8, 2005 | 09:09 PM
aktc167's Avatar
Default power window problem help!!
uh, i was working on my 98 civic ex with dc3 door panels. it was tan so i had the black gsr ones to replace with. when i plugged the civic power window switch to the integra switch...it rowed down a little and stopped working. now i cant use the passenger window. i checked the fuse box under the hood and the window fuse is fine. my driver side works.
Old May 8, 2005 | 11:51 PM
Keno20's Avatar
Default Re: power window problem help!! (aktc167)
Pull the switch (on the door panel) apart and clean the contacts. The contacts get a bit of corrosion on them after a while and just need a clean with a wire brush or what ever. Hope this helps
Old May 9, 2005 | 09:07 AM
aktc167's Avatar
Default Re: power window problem help!! (Keno20)
thx, but the window stopped after i plugged the civic power switch to the integra door panel swtich, it rowed down a little and stopped. i tried using the driver side to role it down and still dont work. the driver side is not plugged into the integra switches...so the driver side window still works. would it be bc the integra switch and civic dont operate the same and just fried it?
Old May 9, 2005 | 10:50 AM
Audi A4's Avatar
yep u prob fried it...
Old May 9, 2005 | 12:48 PM
aktc167's Avatar
Default Re: power window problem help!! (Audi A4)
so what do i need replaced? the switch or the entire wiring system for the power windows and everything else?
Old May 10, 2005 | 07:33 PM
aktc167's Avatar
problem solved lol. i forgot my civic is converted to integra dash and the fuse cover was different, so it was a fuse thx everyone
Jakester9500
Mar 28, 2016 07:57 AM
92-CivicLX
Sep 23, 2013 07:46 AM
robwilhelm
Sep 19, 2007 10:05 AM
aktc167
May 10, 2005 07:34 PM
BauleyCivic
May 1, 2005 04:42 PM
