power window!
hey wsup
my names kingsley and my dilemma is:
my passenger power window got stuck when it was down,
for example when i push the buttons it doesnt go up, no reaction at all.
since it was down i had to get my window up so i can park.
so i took off the door panel, and disconnected the motor? i think it was the motor 2-3 bolts around the middle of the door near and then the window was able to go up n down manually. but yeah, help me! i need to use my window haha.
thanks.. all help appreciated
You sure your connections were all plugged in? You can try and check those, make sure they are not corroded and whatnot. Seeing as how we don't know what year your car is, it could be anything. Might be the motor though. Good luck. You can get one of those from a junk yard for cheap.
Micha
Micha
might not be the motor, try the master window switch first, or the passenger window switch....see if someone has one you can borrow.
examine your own for cracks around the plug.
RGoose18
Aug 28, 2009 10:39 PM
