plugs
Old Nov 14, 2002 | 06:14 PM
Tegra's Avatar
Default plugs
What kind of spark plugs are the best for a 95 integra LS. I have heard to use copper, but I have bosch platinum 4's or whatever now. Are they bad? Whats the difference?
Old Nov 14, 2002 | 06:17 PM
tegasaurus's Avatar
Default Re: plugs (Tegra)
stocks
Old Nov 14, 2002 | 06:20 PM
Tegra's Avatar
Default Re: plugs (tegasaurus)
Why though? Doesnt platinum conduct better? Surely there is an advantage into having 4 spark prongs(whatever they are called)
Old Nov 14, 2002 | 06:25 PM
Johnny Gasparini's Avatar
I didn't ask for a dime.
stocks
Agreed.
Old Nov 14, 2002 | 06:29 PM
Tegra's Avatar
Default Re: plugs (JSM)
*sigh* No facts to back up your suggestions.
Old Nov 14, 2002 | 06:36 PM
Unless you have upgraded your ignition system, there is no need to stray away from stock plugs. The difference between one set and another is how often you change them and of course the material they are made of.
[Modified by JSM, 9:48 PM 11/14/2002]
Old Nov 14, 2002 | 06:45 PM
Tegra's Avatar
so should i just keep my platinums in their until they go bad??
Old Nov 14, 2002 | 06:52 PM
Unfortunately, there is no single answer to this question. As spark plugs grow older, they lose their sharp edges as material from the center and ground electrodes is slowly eroded away. As the gap between these two points grows, the voltage required to bridge the gap increases proportionately. Even the best ignition systems will be strained to supply enough voltage to completely burn the fuel. It is at this point, when fuel is being left unburned, that the time has come to change spark plugs.
Replacing worn out spark plugs with new ones (with sharp new edges) effectively restores the ignition system's efficiency. Misfires are reduced, power is restored, economy of operation is enhanced and emissions are reduced.
Old Nov 14, 2002 | 06:54 PM
Tegra's Avatar
ok, so in theory the "quads" should last longer, because once one starts to wear a little it will arc to another??
Old Nov 14, 2002 | 06:55 PM
I honestly don't know how these "quads" operate.
Old Nov 14, 2002 | 06:59 PM
Tegra's Avatar
Ok, you know how in a regular plug there is one, we'll call "finger" that comes over the top. Well on a quad it has 4. Looks like:
Thats a top view, and the electrode is in the center
Tegra's Avatar
well, more like a cross hair, it didn't post quite right
Old Nov 14, 2002 | 07:01 PM
-Whitey-'s Avatar
the bosh +4 plugs are the way they are so you dont have to gap themthey automatically spark off the closest gap to stock just get some ngk-r plugs and shaddup
Old Nov 14, 2002 | 07:08 PM
Tegra's Avatar
Default Re: plugs (B16A EH2)
wrong, they are all gapped the same. Have you checked? Obviously not. Check it.
Old Nov 14, 2002 | 11:00 PM
SIK IN DA HED's Avatar
New User
NGK. all the other ones suck.
thewiione
10
Jun 13, 2015 09:45 AM
max23
Jun 24, 2006 08:08 AM
gsrguy
Jan 23, 2004 07:04 AM
94Gizzer
Feb 26, 2003 12:44 PM
